SERVICE PORT BIZHUB C364e
  • AhmedChamumi
    • May 2016
    • 131
    Helo everyone,
    Hope this finds you well, kindly assist on the following scenario im currently facing;
    I have a bizhub C364e on which im trying to rewrite firmware and the reason for rewriting firmware is this printer has PKI firmware and i want to install a non PKI firmware because the printer requires authentication in printing and does not allow printing / scanning with thumb drive.
    After inserting the thumb drive containing a non PKI firmware the printer simply boots up normally and ignore the presence of firmware and when it reaches READY TO COPY stage it flashes the message that external drive function is not available, the same thumb drive works perfectly on other printers, i tried to exchange the service port flap and sensor and still the results are the same.
    Is there any setting or procedure i happen to skip? or possibly any parameter in administrator mode need to be changed?
    Kindly assist.
    Ahmed
    THE PRINTER RUNS [A5C10Y0-F000-GDL-M1(00) PKI MFP CONTROLLER FIRMWARE
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: SERVICE PORT BIZHUB C364e
    what size is the drive?
    what brand?
    what exactly is put on the root of the drive?
    ok, can you get to service mode and disable any vendor mode(s) and do a system data clear. then firmware, then movie data?
    • aussieducker
      • Mar 2010
      • 8
      try another thumb drive, 8gb or less. All firmware files in root, not in a folder.
      • copier tech
        • 8174
        Originally posted by AhmedChamumi
        Helo everyone,
        Kindly assist.
        Ahmed
        What version are you trying to install? sometimes trying an older version then work your way up to the latest works.
        • AhmedChamumi
          • May 2016
          • 131
          what brand?
          In root directory i put extracted firmware the expanded version.
          -2GB HP brand drive
          -4GB Sandisk
          Kindly if you happen to have movie data and OCR dictionary for that specific printer please PM.
          Best regards,
          Ahmed
          • AhmedChamumi
            • May 2016
            • 131
            I'm trying to install A5C10Y0-F000-G20-M1
            • larweedad
              • 92
              If I remember correctly you have to install it differently than normally. You need to go through service mode first and turn on download. Read the pdf with firmware.
              Sent from my SM-N960U using Tapatalk
              • emujo2
                • Mar 2017
                • 1579
                You need to set softswitch 41 and 12 back to their defaults..These switchs put the machine in PKI mode...I do not know if this affects the firmware update or not..Usually if the machine just boots as normal, you either have a USB that can't be read, the firmware is not organized on the drive correcly, or the service port is not seeing the shutter open and not looking for firmware. E
                • tsbservice
                  Field tech
                  • 8020
                  G20-M1 update is pretty much standard procedure nothing fancy in my experience.
                    • 23009
                    Thanks Emujo. I wish the DIPSW's had better documentation. Most of the time I have to learn about them from a bulletin or from you. =^..^=
                    • tsbservice
                      Field tech
                      • 8020
                      For the protocol. Maybe Emujo meant soft switches not DIPSW's(often referred as engine FW DIPSW).
                      I may be wrong thought.
                      • AhmedChamumi
                        • May 2016
                        • 131
                        Thanks for the input but i have read read the pdf manual and havent found the procedure you have describe, can you please elaborate.
                        Best regards,
                        Ahmed
                        • AhmedChamumi
                          • May 2016
                          • 131
                          Thanks for your valuable input i get back to you with the results, by the way what is the KMBS recommended brand when it comes to thumb drive?
                          • emujo2
                            • Mar 2017
                            • 1579
                            for this machine I would stick with 4-8 GB..Most models work fine unless they have preloaded software on them. You can download HP' disk formatter tool and use his to truly format and erase any drives. We have been using Scandisk and Transcend for years, but I have various drives that work just as well. E
                            • AhmedChamumi
                              • May 2016
                              • 131
                              Thanks i really appreciate the effort.
