Paper Jam C364
  • Mosespitso
    • 3
    Paper Jam C364
    After switching on the machine, it displays the attached error message, its Konica Minolta C364. Also found on the machine some lose springs
  • Mosespitso
    • 3
    Re: Paper Jam C364
    Please Assist
    • Synthohol
      Certified Konica Expert
      • 5458
      Re: Paper Jam C364
      i remember many times paging through the parts manual magnified trying to locate wee bits that were handed to me upon arrival.
      takes a while but its a start.
      • Sn0wlink
        On-Site Engineer
        • 35
        Re: Paper Jam C364
        The worst is when the customer hands you some screws... Urgh!
        There's the tool the works, Then there's the tool that is Right!
        https://www.sn0wlink.com
          • 22698
          Re: Paper Jam C364
          ... and most of the time the screws didn't even come from your machine!!
          But back to Mosespitso: If you really want to fix something, you'll have to get the jam code from the management list or the jam code history. If your going to be a technician you'll have to figure that out. Read the manual or Google Search.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4213
            Re: Paper Jam C364
            As others suggested you have to go into service mode to see actual jam code. What you see on screen is "location, where to look" for jam.
            I've never seen those parts in a Konica Minolta copier.
            If you are a tech you need to get the service manual and get up to speed with this model. Once you get the jam code that will point you in the right direction.
            If Not a tech I suggest you call one. I've seen too many times customer get in over their head trying to repair the machine themselves. Ends up costing way more $$ then if they called a tech to begin with!
            Don't misunderstand me I'm all for working on stuff and repairing anything myself. I do it all the time around the house, washer, dryer, fans, autos, mini bikes, small engines, etc etc. BUT before I attempt any repair I get the manuals and research the internet for information, etc.
            As for your jamming issue, it could several things, feed rollers, clutch, etc but is usually something simple like dirty sensors, etc
            • CP-1015
              • Nov 2020
              • 285
              Re: Paper Jam C364
              Spring maybe!!! number 28 from conveyance section. First I thought the other part is number 33 from payper exit, but it has onother shape.
              • tsbservice
                Field tech
                • 7635
                Re: Paper Jam C364
                Smaller spring is coming from some sensor actuator. You have to find which one by tapping actuators, one won't return.
                • Synthohol
                  • 5458
                  Re: Paper Jam C364
                  the bigger part looks like
                  A161151200
                  search your part manual for it.
