C554e Custom size problem
  • Amrss
    • 46
    Hello every one,
    I'm having a problem printing on custom sized paper from the bypass tray, the size I want to print on is (500m * 305mm), the driver and the machine's spec sheet show that the biggest size possible (from the bypass) is 1200mm * 320mm, however, once I set the size to what I want (500m * 305mm) and press ok, a massage pops-up telling me that the width will be changed to 297mm.
    what am I doing wrong, how can I solve this problem ?
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: C554e Custom size problem
    Try 12x19. Close enough.
    • Amrss
      • 46
      I can try that, seems really close as you said, but I'm really interested in knowing the reason behind what's happening, there will be times where I won't find a standard size that's close to the custom size that I want
      • copier tech
        • 8176
        Originally posted by Amrss
        Hello every one,
        [ATTACH=CONFIG]47541[/ATTACH]
        Thank you
        Change the paper size at the machine. From the copy screen choose bypass tray then change the size & paper type.
          • 23009
          Will your finishing accessories accommodate the 305mm width? Quite often machine specs don't exactly match finisher specs. You may have to remove the finisher to allow the paper to exit. =^..^=
          EDIT:
          12" x 19.69" (up to 1200mm length by 320mm width) can exit to Output Tray #1, but not Output Tray #2 (maximum 320mm x 457mm).
          Not Offset Group, Offset Sort, Staple, or Folding Tray.
          Only from the Bypass Tray, not any other tray.
          OK, I've got it!
          The largest banner is 297mm x 1200mm.
          The largest page size is 320mm x 460mm.
          You'll have to adjust your image a little for this machine.
          Are we getting closer?
          Checking the Specifications of Optional Components
          • Amrss
            • 46
            EDIT:
            OK, I've got it!
            Thank you sir !
            This problem caused me serious headache
            Turns out that the finisher I have (fs533) is what's limiting the size.
            Again, thank you for your help
            • Amrss
              • 46
              Thank you for your response, turns out my finisher (fs533) is limiting the size
              Thank you
              • tsbservice
                Field tech
                • 8020
                Here it is:
                Checking the Specifications of This Machine
                *2 Banner paper
                Width: 8-1/4 to 11-11/16 inches (210 mm to 297 mm)
                Length: 18 to 47-1/4 inches (457.3 mm to 1200 mm)
                • Amrss
                  • 46
                  Here it is:
                  *2 Banner paper
                  Thank you sir
                  Initially I thought that the finisher was the thing that's causing the problem, but after reading around for a while, it seems that the maximum width size for a banner is 297mm
                  Now I'm having another problem, when I set the dimensions as 500mmX297mm and try to print a paper through the bypass, a message pops up telling me to correctly seat the (A4 paper)
                  • tsbservice
                    Field tech
                    • 8020
                    Thank you sir
                    Printing on Banner Paper
                    • Blizzoo
                      • Aug 2013
                      • 608
                      I think you must set the original size and the output size to be on the same custom paper size you have set in the print driver.
                      • Amrss
                        • 46
                        Thank you so much
                        Please bear with me 😅, I have another problem
                        The machine receives 2 orders whenever I print a file from the pc, one of them is the print job I want, and the other is the one in the photo I'll attach, why is the machine receiving the other order?
                        WhatsApp Image 2020-12-09 at 8.32.33 PM.jpgWhatsApp Image 2020-12-09 at 8.32.33 PM (1).jpgWhatsApp Image 2020-12-09 at 8.32.32 PM.jpg
                        • tsbservice
                          Field tech
                          • 8020
                          I can see only one active job. Place A4 paper on bypass to release it.
                          • Amrss
                            • 46
                            yes exactly, the machine receives this job regardless of what I print, let's suppose that I gave the machine an order to print one paper, the machine would receive the order of that page, AND the order in the photos I attached, (it receives two orders), and even if I place an A4 paper in the bypass tray nothing happens.
                            • Synthohol
                              • 5849
                              Sounds like banner page is turned on. Its a generated "slip sheet" used to separate jobs by sender.
                              There is a setting somewhere to turn off banner pages IIRC.
