C227 boot problem
  • Toxic
    • 698
    C227 boot problem
    I got C227 with no boot,stuck on 2 pillars on screen and just one drive motor is runing.
    Tried disconnect hdd,adf, reseat all connectors on mfpb,sata board,emmc,eeproms...
    When try to boot firmware from usb it stuck on 3 pillars.
    Troublereset dont work.
    Selfdiagnostics procedure dont work.
    Voltage 24V and 5V is ok on mfpb.
    I think it is little bit over 100k counter but machine is from earlier productions (end 2016).
    I would try replace emmc first.
    Some other suggestions?
  • copier tech
    • 8202
    Re: C227 boot problem
    Try the NVram reset tool.
      • 23010
      I would try replace emmc first...
      Me too. Or if maybe a memory DIMM (if there is a removable memory DIMM).
      • tsbservice
        Field tech
        • 8053
        +2
        On third pillar machine would access eMMC board obviously it can't.
        • Toxic
          • 698
          Machine does not have optional memory DIMM, only onboard.
          Is there nvram reset tool for C227, i never see it before...?
          • tsbservice
            Field tech
            • 8053
            Toxic search infohub for a789be.tar
            If you're unable to find it I can search in my docs Monday.
            • Toxic
              • 698
              I found that file in my 8 series folder, did not know it is the same for 7 series.
              To be honest, never have need to use this reset file.
              • tsbservice
                Field tech
                • 8053
                Me too but better be prepared than sorry is my Mojo.
                • copier tech
                  • 8202
                  Yes, nothing to loose, worth a try before ordering expensive boards.
                    • 23010
                    Just saying, I've had to call the hotline for a CE password reset every time I've used the MFPB reset Tool. =^..^=
                    • tsbservice
                      Field tech
                      • 8053
                      eMMC boards for 7/8 series aren't exactly one of expensive boards they're comparatively cheap.
                      • Toxic
                        • 698
                        I will contact KM at monday anyway about emmc.
                        What is approximate price for this emmc TSB?
                        • tsbservice
                          Field tech
                          • 8053
                          • copier tech
                            • 8202
                            I'd always try f/w first before ordering any parts no matter what the cost, quite often this will save a 2nd visit. i'm all about first time fix.
                            • allan
                              RTFM!!
                              • 5462
                              +2
                              Ok so there is meaning behind those fins. Only ever had them stuck of 2 fins.
                              Is that info in the service manual?
                              Does it then lock you out of service mode, or did you use it to clear the CE password?
                              My experience of using the reset tool is not that rosy. But it did help to get machines up and running but it leaves ghosts behind to pops up.
                              They can also take with it values from a used board. Life stop setting, Toner levels, life counters that did not "reset".
                              One guy that started a electronics repair lab. He had a deal with the local dealers and collected all the failed boards. Including some of the warranty parts that was supposed to be shipped back. You need the error code or some other fault description to get anywhere. If you are luck only re flowing the solder can fix bad
                              joints. None of the boards he had came with a description of the fault so it made it difficult to trace the problem. You will be surprised at how many was nothing but an ICP. Made good money at selling the stuff back to them.
                              Im not much of a board changer or a firmware jockey for that matter. Replacement board costs a tone and can screw you if you are independent.
                              Whatever
