C227 boot problem
  • tsbservice
    Field tech
    • 8053
    #16
    Re: C227 boot problem
    I'd always try f/w first before ordering any parts no matter what the cost, quite often this will save a 2nd visit. i'm all about first time fix.
    While normally I agree with you this case isn't just regular one.
    Therefore some alternatives should be considered atleast I would. For example I know if machine isn't sold from local KM main distributor but imported second hand they can refuse you to issue CE password reset code. As BC mentioned without CE password reset code you're stuck outside CE mode. Not really desirable. But I guess it depends on Toxic's case. It's always better have plan B.
    • Toxic
      • 698
      #17
      Nice thinking from everybody, i must agree with all at some point.
      If machine is mine/leased i would go for most cheap good solution but in this particular case i got machine from customer who buy it from us few years ago and just one time buy black toner.
      Now i see he used some replacement toners inside machine bought who knows where and in cases like that i mostly go for repair in "officially by the book " way.
      For mine loyal customers i usually make the best and most cheap solutions possible in every situations.
      For @allan
        • 23010
        #18
        That's good information!
        Thanks Toxic. =^..^=
          • 23010
          #19
          Originally posted by allan
          Does it then lock you out of service mode?
          Every time.
          • allan
            RTFM!!
            • 5462
            #20
            Every time.
            Reset tool on the 4 series never gave me issues.
            So only on the newer machines?
            Whatever
            • tsbservice
              Field tech
              • 8053
              #21
              I don't know for sure allan but I would trust BC.
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                #22
                Originally posted by Toxic
                I got C227 with no boot,stuck on 2 pillars on screen and just one drive motor is runing.
                Tried disconnect hdd,adf, reseat all connectors on mfpb,sata board,emmc,eeproms...
                When try to boot firmware from usb it stuck on 3 pillars.
                Troublereset dont work.
                Selfdiagnostics procedure dont work.
                Voltage 24V and 5V is ok on mfpb.
                I think it is little bit over 100k counter but machine is from earlier productions (end 2016).
                I would try replace emmc first.
                Some other suggestions?
                Bad news guys. The print controller is toast. Its time for a new machine.
                • Synthohol
                  Certified Konica Expert
                  • 5894
                  #23
                  dude, check the post dates.
                  necroposting
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4766
                    #24
                    ha-ha. where did this imbecile come from. He has the balls to show up here and start posting on old threads. Looking at his answers the question should be is he a tech?
