Bizhub C221 error code 3925
  • r4roty
    • Jan 2017
    • 8
    [Error Code] Bizhub C221 error code 3925
    Hi all
    How do I reset c3925 error after removing the fuser unit of this machine to enable me remove the transfer belt but in the process a wire pulled out from the center temperature sensor plug jack harness located on the right side of the side door? I entered service mode input CE password, but could not find fuser reset. This copier control and display is different from other BIZHUB
    Please any ideas will be much appreciated
  • Synthohol
    Certified Konica Expert
    • 5879
    Re: Bizhub C221 error code 3925
    it would be trouble reset not fuser reset.
    i dont think that model was sold in the US, i didnt see it in MKM anywhere.
    • tsbservice
      Field tech
      • 8042
      I think you will need Service manual if what Synt suggested don't work.
      • copier tech
        • 8196
        Originally posted by r4roty
        Hi all
        If you have reconnected the wire run trouble reset.
        Trouble reset Konica C221 - YouTube
        • r4roty
          • Jan 2017
          • 8
          thanks problem solved
