C364 not printing black
  • Chris@paloffice.com
    • Jul 2019
    • 1
    I have a c364 that refuses to print in black. Internals, customer network, faxes. All blank. Printing a demo page... the colors are beautiful but the blacks are just missing. Drums turning but no image is being laid down. I had a C203 do the exact same thing about 5-7 years ago but don't remember my solution. I'm going to try firmware but I was looking for other areas to look at while I'm on site. I appreciate your help!
    Re: C364 not printing black
    are the dev units turning?
    what about the K laser?
    it sounds like a hardware problem not software.
    when did this problem pop up?
    what's the count on PM parts and supplies?
    Phil B. ' The Dentist '
    • Synthohol
      Certified Konica Expert
      • 5846
      jig the door and WTB and shine flashlight on drum during copy see if it prints a black streak.
      you said the drums are turning, ho 'bout the DV unit? does the mag roller have a nice "brush" on it or are there bare spots?
      • Reed
        • Feb 2011
        • 258
        Check Developer unit. Maybe one of the gears on the back of the unit is bad so that the developer unit isn't turning
        • Gift
          • Mar 2011
          • 2459
          Or a faulty DV clutch: wipe a little dev away from the mag roller so there's a free sport, then re-insert to the machine, let it run and then check if the mag roller turned. If the spot is thill there it's proably a drive or clutch related issue.
          • tsbservice
            Field tech
            • 8020
            If anything mentioned fails I would be looking at black developer unit solenoid SD4 (A161M20300 Flapper solenoid).
            • Blizzoo
              • Aug 2013
              • 608
              If everything mentioned above doesn't solve try to jig front door, pull half-way the charge cleaning rod for K and do a copy/print. You should get a black horizontal line in the same position where the cleaning tip has been pulled to revealing that the HV is suppliyng charge
              • copier tech
                • 8172
                Stop the machine half way through printing, check to see if your black image is on the belt?
                • MVPunisher
                  • 209
                  I had this solenoid fix a similar issue for me twice. Once it was just gummed up from the pad and the other time it failed..
                  • kingarthur
                    • 1369
                    I totally agree....this is basic fault finding. Whenever I've had this problem, it's been the gear on the drive unit that meshes with the DV unit and the one on the end of the DV unit have both failed....I replace the DV unit, and strip down the main drive unit & replace the gear....haven't purchased a new drive unit for years....
                    • copier tech
                      • 8172
                      Now you've been given help, any update on you one & only ever post?
                      • REGSIS
                        • May 2016
                        • 435
                        Agree!
                        Solenoid which releases and stop black dev clutch would be my first suspect on a high meter machine (or old one).
                        C364 is 7 years old at least.
                        Open PWB box and take out the solenoid.
                        Remove old sponge (od what is left of) and glue a thin layer of cardboard.
                        Better than new!
                        • TEST10
                          • Jun 2010
                          • 69
                          Could you please explain to me what function this solenoid has, because when I disconnect it I recover the black printing!
                          • TEST10
                            • Jun 2010
                            • 69
                            Under what circumstances should the unit brake, what is its function?
                            • REGSIS
                              • May 2016
                              • 435
                              Originally posted by TEST10
                              [LIST][*]
                              Its function is to release and stop rotation of developing unit at specific time.
                              Sponge on solenoid acts as isolator, if it's worn timing is wrong.
                              Nothing is broken, solenoid works, all you have to do is to repair the isolator (sponge) with a piece of cardboard.
                              Or buy a new part but it will last only 5-7 years.
