Ineo +658 Drum Lines.
  • damonc
    • Oct 2012
    • 4
    [CQ] Ineo +658 Drum Lines.
    We have a Develop Ineo +658 which is constantly putting lines on the colour drums. It was running non genuine drums and toner, but is now on genuine drums and toner. You can clean the charge roller and cleaning roller, but only last a few weeks. Its a heavily used machine. Anyone got any ideas?
  • Bix
    • Apr 2018
    • 1421
    Re: Ineo +658 Drum Lines.
    Make sure you are using the correct drums. If of other models it might work but last less than half life.
      • 23007
      DR-313 or DR314 drums?
      I recently learned that DR-313 drums will fit but do not last very long. I'm seeing ~200K on DR-314 drums.
      • copier tech
        • 8142
        It will take a while for the non genuine toner to 'flush out'
        • tsbservice
          Field tech
          • 8008
          BC I think this machine use DR-313 as color drums. DR-314 is black drum unit for monocolor 368e-658e models.
          OP what exactly drums and toners are put in the machine now?
