firmware question C554e
  • digicor
    • Jul 2008
    • 1158
    Will G20-M0 firmware work in a c554e?
    its for the c654/754e just asking if it will do the same job
    thanks for any insight
  • copier tech
    • 8164
    Re: firmware question C554e
    No the C654e/C754e use different firmware.
    C224e - C554e use the same.
    • Synthohol
      Certified Konica Expert
      • 5836
      The version is irrelevant, the first 7 characters the firmware denote the model it applies to.
      Ie: a92f011 is for a c3351
      So if the current fw in the machine has a different prefix then no it won't work.
      • digicor
        • Jul 2008
        • 1158
        okay thanks
        i have the c224 ,
        refresh me, does it need to be the only thing on the thumb drive and does it have to be opened or can it stay in the folder?
        thanks,
        • Synthohol
          • 5836
          4 series gets the opened zip contents, (see pic below) on the root as pictured.
          the 8 series only gets the FW000xx folder on the root
          • digicor
            • Jul 2008
            • 1158
            got it thanks guys
            • konixcavn
              • Jul 2021
              • 3
              • copier tech
                • 8164
                We can supply you with the latest version. Please contact us at the links below.
                • konixcavn
                  • Jul 2021
                  • 3
                  Hello All!
                  Can anyone help me with the firmware C454e/C554e! Thank you. Email: ricohaficiolenguyen@gmali.com
                  • copier tech
                    • 8164
                    Originally posted by konixcavn
                    Hello All!
