C258
  • Kent
    • Feb 2018
    • 17
    C258
    getting a random black line running top to bottom on letter portait, it goes completely edge to edge and not in the feed direction, all the consumables are at 50%, line was noticed when printing but I duplicated it with copying as well,, transfer belt was replaced
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: C258
    can you post a sample?
    • lartis.aineias
      • 78
      Re: C258
      Check the Belt cleaner or bk drum cleaner!
      Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
      • tsbservice
        Field tech
        • 8010
        Re: C258
        Weird. As Synthohol mentioned post a sample. Do the black line appears on color print?
        • Kent
          • Feb 2018
          • 17
          Re: C258
          black line shows up on everything
            • 23007
            Re: C258
            Image sample? I'm not going to speculate until I see the sample. =^..^=
            • Kent
              • Feb 2018
              • 17
              Re: C258
              Ill post samples after the weekend
              • Kent
                • Feb 2018
                • 17
                Re: C258
                SFishers Sp21010408420.pdfhere are samples
                • Synthohol
                  • 5823
                  Re: C258
                  Looks like drum/charge roller.
                  You can print the 4 gradation test patterns to see which drum it is.
                  [edit]forgot the part about top to bottom, sorry.[/edit]
                  • tsbservice
                    Field tech
                    • 8010
                    Re: C258
                    Any non genuine consumables used? As I said lines perpendicular on paper feed direction are weird. You should run Stabilization followed with gradations and then print CMYK test patterns.
                    • copier tech
                      • 8144
                      Re: C258
                      Originally posted by Kent
                      [ATTACH]47765[/ATTACH]here are samples
                      Are you rebuilding the image units?
                      • Bix
                        • Apr 2018
                        • 1421
                        Re: C258
                        I have had a similar problem: is the transfer belt cleaning blade. If you take it apart, you can vacuum it with the vacuum cleaner. Warning: if the toner granules have made the groove, you must replace the transfer belt because the line will probably come back.
                          • 23007
                          Re: C258
                          If you look at the color density where the line passes through the 40% fill squares, you'll see that the color density CMYK ratio stays the same as the rest of the box, just more dense.
                          If it were a primary transfer cleaning issue the lines would be composite black in color, so it's probably not primary transfer cleaning.
                          Since it affects all colors equally it must be a primary transfer or secondary transfer issue.
                          There might be a primary transfer drive issue causing a compression.
                          There might be variation in the transfer voltages.
                          If you had a like machine i would try the primary transfer belt, and second transfer roller each separately. I think you'll find that it's a primary transfer issue. I've seen something similar on a Kyocera Matsuri series, and a Toshiba Weisshorn 2H series. In both cases one of the electrical contacts was either out of position (not touching the facing roller or bushing), or I had left off a contact spring to the facing roller at the cleaning unit end.
                          Does any of that help? =^..^=
                          • Kent
                            • Feb 2018
                            • 17
                            Re: C258
                            Got there this morning and lines were gone ran some tests asked users and it has been fine,,Im not thoroughly convinced will wait and see
                            • tsbservice
                              Field tech
                              • 8010
                              Re: C258
                              Makes sense to me especially as OP mentioned of transfer belt replaced but wasn't specific about whole new genuine TBU or just aftermarket belt only.
