Use Toner for C360 in a C364
  • technics1210
    • Oct 2020
    • 16
    Hello,
    I have a lot of toners for a Bizub C360. However, I no longer have the printer. Now it's a C364.
    Can I transfer the toner to the cartridge for C364?
    How does the level indicator work?
  • Synthohol
    Certified Konica Expert
    • 5827
    Re: Use Toner for C360 in a C364
    it goes by the chip on the bottle, not the volume of contents.
    sorry i cannot help the other question, in the 22+ years working on copiers i have never needed or wanted to try toner not specifically made for that model.
    in fact, i've walked off a job when the owners of the company were ok with doing that.
    • eccelobo
      • 113
      Originally posted by technics1210
      Hello,
      I just use toner for C8000 in both C360 and C364 models and never had a trouble.
      The chip is fot the indication of amount. You can use the same chip, it will indicate zero but it lets you print (unless the bottle gets empty and then you'll have to replace the chip).
      Good Luck!
        • 14735
        Hello,
        The toner level bar graph gets reset after a toner empty condition is reached and the front door is opened. The chip on the C364e toner only tells the machine that the toner bottle is present, it does not have a counter on it.
        • allan
          RTFM!!
          • 5462
          Only K will be the same the colors will not replenish the developer and your dev tanks will fail way before yield.
          In fact the dev tank yield will be the same as for a C360 on your C364.
          Whatever
          • tsbservice
            Field tech
            • 8018
            Both C360 in a C364 machines don't have chips on toner cartridges. And as allan said you need to control amount of CMY developers very closely because there isn't developer in color toners for C360.
            • tsbservice
              Field tech
              • 8018
              That would be ouch if he makes a lot of color copies. CMY developer units life 4 times shorter than expected.
              • allan
                RTFM!!
                • 5462
                Ninja move will be to get generic CMY developers and adding small amounts to the toners. A table spoon on a bottle should do the trick.
                Excess dev should be discarded into the waste box...
                Whatever
                • technics1210
                  • Oct 2020
                  • 16
                  okay, then it's not as easy as I thought.
                  I think I'll test a color and then let's see.
                  Thanks for your help
                  • Synthohol
                    • 5827
                    Then what is this?
                    • allan
                      RTFM!!
                      • 5462
                      Originally posted by Synthohol
                      Then what is this?
                      TN512 chip? C454, C554.
                      TN321 does not have a chip.
                      Chip is nothing but a fuse. Only for new article detection and resting the bars.
                      Believe there is a SW to fool the machine.
                      Whatever
                      • allan
                        RTFM!!
                        • 5462
                        I take the TN512 chip off for the 364 machines and cut the fins to make it fit.
                        Then use the fuse from the chip to reset the drums and devtanks.
                        TN512 cheaper than TN321.
                        Whatever
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4708
                          There are no chips on these toners. It would probably work since drums, developer powder & blades are the same (not the complete units just aftermarket drums,blades & dev powder)
                          I wouldn't attempt on a customers machine but if your machine or a machine in shop give it a try. I have swapped toners a few times from one model to another in a pinch with no problems.
                          • tsbservice
                            Field tech
                            • 8018
                            Then what is this?
                            Toner cartridge set board.
                            • allan
                              RTFM!!
                              • 5462
                              Problem i have with rebuilding these would be that the charge unit corrodes before you can get max value.
                              Whatever
