Hello,
I have a lot of toners for a Bizub C360. However, I no longer have the printer. Now it's a C364.
Can I transfer the toner to the cartridge for C364?
How does the level indicator work?
Ok so the quick answer is yes.
However you will need to 'decant' the C360 toner into your C364 bottles.
Problem i have with rebuilding these would be that the charge unit corrodes before you can get max value.
Been rebuilding the drum units with new drum,blade, sawtooth, grids & chips for over 2 years now with great success! Only had 2 fail out of hundreds because of blade flip which was my fault. I used setting powder instead of yellow toner which is the best lube for drum & transfer belt blades.
This is why you see 2nd transfer rollers are yellow in new machines. Factory uses yellow toner to lube everything. Not sure what's in yellow toner that is different but if factory uses it, it's good enough for me!
I dont understand, some guys here claims toner bottle have chips and others, it does not.
In my case i never see chip on TN321 bottles.
TN324 have chips.
Maybe different regions is reason for this or something else?
TN324 have chips.
No they don't have chips on the toners.
You can actually run the machine with all the toners removed the machine won't prompt you to install them.
It will only ask you to add toner when the TNR % in the hopper drops.
Katun has C258 compatible toner with C454e.I have original TN-512 and my question would be if anyone has tried putting the original TN-512 in a C258. I have not C454e and have a lot of this toner ,both bottles have chip.If not I try . Thanks
