Konica Bizhub 600 Network Not Working To Pc
  • manzoorwighio
    • Dec 2019
    • 28
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica Bizhub 600 Network Not Working To Pc
    assuming you can ping the copier or access copiers web page
    just click "The printer I want isnt listed"
    then add a printer using ip address
    • wjurls
      • Feb 2017
      • 498
      To install a 600 print driver you want to use the "add printer" method and manually enter the IP address and use the .inf file.
      • K-3
        service technician
        • Feb 2018
        • 51
        the 600 needed the ic202 image controller to print if it is not there or damaged, maybe why you can't print.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4721
          Are you sure it has the printer chip installed for printing?
          Print configuration page and it will show if installed
            • 37532
            I noticed that one of the LEDs next to the network connector was blinking rapidly. Jabber like that could means that the connection is being hammered. It could be the network interface in the Bizhub or it could be the switch/hub/router that it is connected to. Try connecting directly to your laptop. If you still get jabber it is most likely the Bizhub
            • manzoorwighio
              • Dec 2019
              • 28
              I tried to replace this this card from working machine but no luck
              • emujo2
                • Mar 2017
                • 1579
                The IC 602 was a 8 pin EEPROM looking device..I'm not sure what you are showing...Out of the box it was a copier/scanner..No printing without the IC..E
                • allan
                  RTFM!!
                  • 5462
                  Originally posted by manzoorwighio
                  [ATTACH=CONFIG]47846[/ATTACH]
                  Looks like IROM if there is a battery on the back its the NVRAM. I would suggest putting back the original one.
                  Whatever
                  • emujo2
                    • Mar 2017
                    • 1579
                    After watching the video again...This is a pretty old machine..If the network card is configured to auto negotiate, it may never connect to a 1gb port.try setting the port to 100 full duplex. If this is a DHCP environment try restarting in DHCP and see if you can pull an address. Another thing would be to go into Admin and turn OFF TCP/IP , cycle power, then turn TCP/IP on. this is like a NIC reset. Also..someone refresh me..did the 600 need a x-over to connect directly back to a laptop? E
                    • K-3
                      service technician
                      • Feb 2018
                      • 51
                      looks like the right unit, try what emujo said in his post. if it will not pull a ip address by dhcp the board maybe bad or the board it connects too may be bad. i believe you need a x-over cable for laptop or try a standard 4 port switch to create a mini network.
                        • 37532
                        If the laptop is new enough then a crossover cable is not needed. The laptop I bought in 2005 required one on older models. Every one I have used after that one did not.
                        • emujo2
                          • Mar 2017
                          • 1579
                          It's not the laptop..older NICs could not directly connect back to another nic w/o going through a switch or hub. This is only a problem connecting directly to a printer from your laptop via ethernet. E
                          • Synthohol
                            Certified Konica Expert
                            • 5847
                            Autocrossover is on the (newer) PC side, the nic on the copier is irrelevant.
