konica c360 problem
  • enricocopyline
    • Jun 2018
    • 124
    konica c360 problem
    the printer scans and photocopies but does not print from the PC or the demo page and if you insert the key it tells me external memory detected. this feature cannot currently be used. when a print is launched on the pc it says printed the machine flashes the blue light but does not print. I have already formatted the hard disk I cleared all data I checked that the printout with code is not inserted. what can cause this problem? has it happened to someone? thanks for the help
  • wynter17
    • Mar 2019
    • 33
    Re: konica c360 problem
    Maybe a bad network cable
    Sent from my SM-G980F using Tapatalk
    • KM7155
      • Aug 2008
      • 148
      all the PC same outcome? make sure the secure print is not ticked.
      • enricocopyline
        • Jun 2018
        • 124
        secure printing is not checked but as well as from the pc it does not even print the demo page or even from a usb key
        • rrrohan
          • Sep 2011
          • 1977
          Check job log
          Sent from my Pixel 4 XL using Tapatalk
          • copier tech
            • 8206
            I had this exact issue a few weeks ago.
            The fact that it wont print the demo page you can rule out any network or driver issues.
            For me I updated the firmware & the issue was resolved, I think it may have become corrupted somehow.
            Also check you don't have account track etc enabled.
            โ€‹
            • allan
              RTFM!!
              • 5462
              Make sure consumables are set to no-stop in service mode.
              Anything out of life?
              Also try to do system error clear. Initialization could also help.
              Whatever
              • tsbservice
                Field tech
                • 8059
                Allan he did initialize. And if life stop is hitting there he can't copy also I think.
                I would try first to update FW as copier tech suggested.
                  • 23010
                  A lot of these machines came defaulted to disable Direct Print from USB. Make sure it's ON.
                  Can you view the webpage?
                  Will it ping?
                  Are there any errors stored?
                  Will it print internal lists like the Management List or Counter Page?
                  • allan
                    RTFM!!
                    • 5462
                    My bad. Will teach me to read.
                    Whatever
                    • enricocopyline
                      • Jun 2018
                      • 124
                      fixed with firmware update thank you very kind
                      • copier tech
                        • 8206
                        Well done, thanks for the update.
                        Firmware Update - Printer & Copier Firmware
                        โ€‹
