C224 Bizhub general maintenance
  • hquang
    • Jan 2021
    • 31
    #31
    Re: C224 Bizhub general maintenance
    me thinks this will explain everything :
    About hquang
    Country:Canada ... Where are you from (City, State):Point Roberts....Technician ....Status: End-User (Non-Tech / User)
    NUFF SAID?
    I was in a hurry when register to this forum. I have no idea why Point Roberts....Technician!
    • hquang
      • Jan 2021
      • 31
      #32
      Agreed. This is one of those learning moments.
      Some things its better to have good reason to remove. You can learn the easy way, or the hard way. Its up to you.
      Yes I am learning and much appreciated for ALL feedback.
      • allan
        RTFM!!
        • 5459
        #33
        One thing i have learned over time is. If it ain't broken don't fix it. When its broken fix it properly.
        Even the most experienced tech can cause themselves trouble by scratching were it does not itch.
        Whatever
        • hquang
          • Jan 2021
          • 31
          #34
          You don't think there's any electronics in the doc. feeder tray? How do you think it reads the size of the paper? I'd listen to blackcat if i were you or you may be starting another thread asking how to repair what you just broke. Just saying....
          the part 1 which is just piece of plastic, no electronic involved.
          I may be wrong but still don't see any wiring, cables, connectors connected to that tray. Unless there is a sensor looking at it but that sensor (if any) is not attached to the tray.
            It's difficult for me to believe that you're a tech and you don't know that there are size sensors in that "piece of plastic." Do you think the techs on here are pulling your leg? Stop talking about it and just take it off. I honestly don't know what else to say. Good luck.
            • hquang
              • Jan 2021
              • 31
              #36
              NO, I am not a tech...I have no idea why someone put 'technician' to me.
              I do appreciate your help and ALL other gentlemen in this forum. DON'T misunderstand me please! How can I change it?
              • allan
                RTFM!!
                • 5459
                #37
                The wiring goes thru the rear hinge point... You need to remove covers and then undo some other stuff.
                Never had the need to to remove one of those in a very very long time. And that was to repair a wire i broke while messing with something i should not have messed with.
                Whatever
                • hquang
                  • Jan 2021
                  • 31
                  #38
                  Originally posted by rrrohan
                  You'll want to clean it and reinstall it
                  Pull the shaft out, clean it. Don't lube it just clean
                  Blow out the rollers where shaft slides through
                  Clean any dried toner off rollers (if any)
                  Reassemble
                  Reinstall.
                  In regards to the DF don't waste time taking it apart. Nothing a paint brush, blower and some spray and wipe can't fix
                  Sent from my Pixel 4 XL using Tapatalk
                  Thanks rrrohan
                  • hquang
                    • Jan 2021
                    • 31
                    #39
                    I AM NOT a technician
                    How can I fix this?
                    Thanks in advance
                      [ATTACH=CONFIG]47992[/ATTACH]
                      How can I fix this?
                      Thanks in advance
                      look at the top of the page...
                      profile
                      edit incorrect info
                      done
                      be truthful .. we will bust you on any fake info.
                      also while you're at it review FORUM RULES and the FAQ's that info is vital here.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        #41
                        I have removed all the screws belong to the part 2 but cannot take it out now I just want to know how to remove the part 1 which is just piece of plastic, no electronic involved. It does not look difficult but I can figure it out how to do it.
                        [ATTACH=CONFIG]47990[/ATTACH]
                        There is one screw hidden under part 1
                        Hinge part 1. I'll see it. If you want to left part 1 further just flex it past the rear cover.
                        But I wouldn't remove it, you can easily clean it left installed
                        • hquang
                          • Jan 2021
                          • 31
                          #42
                          profile
                          edit incorrect info
                          done
                          End-user now but still shown Technician!
                          • hquang
                            • Jan 2021
                            • 31
                            #43
                            Hoorah rrrohan,
                            Thanks to your instruction I've lifted part 1, removed and cleaned part 2.
                            The only tricky part is putting it back since the screws holes are in deeper level.
                            Again thanks,
                              • 22968
                              #44
                              I think you need to work on one particular skill:
                              Taking advice.
                              Five different people tell you that it's entirely unnecessary, and that you can cause yourself additional heartache by doing so, but you didn't listen.
                              I can understand being stubborn. I'm fairly stubborn myself, but when (5) different people tell me something I have to consider: "Is this a good idea?" These people probably know more than me.
                              • Hansoon
                                • Sep 2007
                                • 3358
                                #45
                                LOL
                                That's what your wife says, Cat?
                                Hans
                                “ Sent from my Intel 80286 using MS-DOS 2.0
                                https://www.copytechnet.com/images/smilies/biggrin.png
