C224 Bizhub general maintenance
Re: C224 Bizhub general maintenance
the part 1 which is just piece of plastic, no electronic involved.
I may be wrong but still don't see any wiring, cables, connectors connected to that tray. Unless there is a sensor looking at it but that sensor (if any) is not attached to the tray.Comment
It's difficult for me to believe that you're a tech and you don't know that there are size sensors in that "piece of plastic." Do you think the techs on here are pulling your leg? Stop talking about it and just take it off. I honestly don't know what else to say. Good luck.Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
I do appreciate your help and ALL other gentlemen in this forum. DON'T misunderstand me please! How can I change it?Comment
The wiring goes thru the rear hinge point... You need to remove covers and then undo some other stuff.
Never had the need to to remove one of those in a very very long time. And that was to repair a wire i broke while messing with something i should not have messed with.WhateverComment
You'll want to clean it and reinstall it
Pull the shaft out, clean it. Don't lube it just clean
Blow out the rollers where shaft slides through
Clean any dried toner off rollers (if any)
Reassemble
Reinstall.
In regards to the DF don't waste time taking it apart. Nothing a paint brush, blower and some spray and wipe can't fix
Sent from my Pixel 4 XL using TapatalkComment
I AM NOT a technician
How can I fix this?
Thanks in advanceComment
profile
edit incorrect info
done
be truthful .. we will bust you on any fake info.
also while you're at it review FORUM RULES and the FAQ's that info is vital here.Comment
I have removed all the screws belong to the part 2 but cannot take it out now I just want to know how to remove the part 1 which is just piece of plastic, no electronic involved. It does not look difficult but I can figure it out how to do it.
[ATTACH=CONFIG]47990[/ATTACH]
Hinge part 1. I'll see it. If you want to left part 1 further just flex it past the rear cover.
But I wouldn't remove it, you can easily clean it left installed
Thanks to your instruction I've lifted part 1, removed and cleaned part 2.
The only tricky part is putting it back since the screws holes are in deeper level.
Again thanks,Comment
I think you need to work on one particular skill:
Taking advice.
Five different people tell you that it's entirely unnecessary, and that you can cause yourself additional heartache by doing so, but you didn't listen.
I can understand being stubborn. I'm fairly stubborn myself, but when (5) different people tell me something I have to consider: "Is this a good idea?" These people probably know more than me.
=^..^=If you'd like a serious answer to your request:
