C224 Bizhub general maintenance
  • hquang
    • Jan 2021
    • 31
    Hi All,
    This is my second post. The first one is a problem with Tray 2 of my C224 and it solved in 24hrs.
    This post I am going to ask about the maintenance for the C224.
    I use this printer around 6 years not heavily. In time I found it generates squeaky noises when paper coming out from inside. Looks like it needs oil.
    Do we have a way to lubricate the machine or a form of maintenance?
    Thank you,
    Hien
  • rrrohan
    • Sep 2011
    • 1977
    Re: C224 Bizhub general maintenance
    id take out the rollers above fuser. the one with 4 black rollers. its only 3 screws.
    that is pretty common to generate squeaks and if it is that just make sure you remove the silver shaft and clean it and blow out any dust from the insude of the black rollers
    I wouldnt lubricate it just make sure its clean
    • hquang
      • Jan 2021
      • 31
      I need more specific to the location of the printer parts: fuser, rollers, silver shaft... I am not a tech guy but will try my best.
      Thanks,
      Hien
      • hquang
        • Jan 2021
        • 31
        Hi rrrohan,
        Is it the part in the red rectangular?
        • rrrohan
          • Sep 2011
          • 1977
          Yes the bit with 4 black rollers
          Take 3 screws out. Left middle and right
          U should be able to print one page without it installed and confirm if squeak gone
          Sent from my Pixel 4 XL using Tapatalk
          • Bix
            • Apr 2018
            • 1421
            On a bizhub 458 I once tried to disassemble but I realized that the three screws were not fixed. Perhaps the heat of the oven has dilated the holes and could be removed without unscrewing them.
            About your problem, check this thread: Bizhub C284e noise
            In my case, it looked like a fuser problem. I simulated the opening of the door and I realized that in reality the problem came from somewhere else.
              get yourself a manual ...
              it has a section on maintenance read it
              • copier tech
                • 8195
                Originally posted by hquang
                Hi All,
                Thank you,
                Hien
                A squeak is genuinely nothing to worry about, most of my 5 year old Bizhubs all squeak simply ignore it.
                • hquang
                  • Jan 2021
                  • 31
                  I have something else to clean. How to remove these parts from the top of the C224? I remove all screws from part 2 but it still get stuck somewhere underneath part 1. I can't find any maintenance chapter in the manuals I have.
                  Please help!
                  • Synthohol
                    Certified Konica Expert
                    • 5873
                    the latch pins get in the way.
                    take off the covers and unscrew the pin that most annoys you
                    • copier tech
                      • 8195
                      Please help!
                      [ATTACH=CONFIG]47986[/ATTACH][ATTACH=CONFIG]47987[/ATTACH]
                      No idea how this is relevant to this post regarding a squeak?
                      • hquang
                        • Jan 2021
                        • 31
                        Can you be more specific - I don't get where are the covers?
                        • copier tech
                          • 8195
                          A copier squeak can be very tricky to track down even for an experienced tech.
                          Plus it is IMPOSSIBLE to troubleshoot a squeak on a chat forum.
                          • hquang
                            • Jan 2021
                            • 31
                            Sorry I thought it related to 'general maintenance'. Should it be deleted now ?
                              • 23010
                              +1
                              Not to be critical, but I don't see why the document feeder tray needs to be removed.
                              My recommendation is to leave the DF tray on, and clean the rubber rollers. This probably does not have anything to do with your squeak.
