Bizhub C224e/C258 series fuser premature failure
  • Hansoon
    • Sep 2007
    • 3374
    #16
    Re: Bizhub C224e/C258 series fuser premature failure
    Originally posted by Bix
    What do you think about Aliexpress?
    Page Not Found - Aliexpress.com
    "Goodpartner" was the one who supplied my famous aftermarket thermistors......
    Got from Chinaman.......
    Hans
    • tsbservice
      Field tech
      • 7986
      #17
      Hans
      Yeah I glanced over the link Bix provide and chuckled when see that 'Goodpartner' company.
      • Oystercopy
        • Oct 2009
        • 623
        #18
        I'm all FOR rebuilding the fusers instead of tossing them. I can't tell you how many Bizhub fusers I've taken apart and all it (usually) takes is some high temperature oil (I use DuPont Krytox) that saved the fuser from having to be replaced, when
        they're squealing. Seems to happen (some) with less than 30K. I could see not doing it if the fuser has reached yield, but most are not making it that far.
        Plus, if you think about it, where do all your REBUILDING skills go when you never use them, and just keep REPLACING $500 fusers.. that's right, they will be gone.
        I buy my parts from China suppliers as well to rebuild some of these things, but unless you work for a large dealer, who's got $$ to burn, why not at least TRY to repair it?? If I break down the fuser however, and there are seriously worn components, then YEAH, you may not even be able to get some of the bushings/gears that you would need to rebuild it. But its certainly worth a shot.
        And I'm in business for myself and every penny counts, people! Been doing it this way in my own business for 26 years; seems to work well, most often.
        OC
        • Hansoon
          • Sep 2007
          • 3374
          #19
          Forgot to mention in my previous thread that I ordered from that source, this time not noodles, but two sets of each four thermistors. The first set coded out immediately with C-3923 indicating "thermistor wire break"
          Well, "Shit Happens" was my first thought and left the machine alone for the next Saturday finding time to work on it so one week later I installed the second set, but than.............
          I claimed this first set of thermistors for replacement already but no reaction from them yet
          Hans
          • allan
            RTFM!!
            • 5462
            #20
            Originally posted by tulintron
            In the first disassemblies, I confess that I did not like doing them. But with practice, you improve the work.
            Your knowledge will make the process easy. The result will tell you how much it is worth
            How long does it take to rebuild a C554 fuser?
            Did my first one on site, took lots of pictures. Feels like you are taking it to bits to get to the point you can change the rollers. Had to undo and redo some things not really knowing the sequence of reassembly. After the rebuild i got real bad fusing with the toner sticking to the belt. Was relieved that it was only me not hooking in the pressure springs. Quality was A OK. That first one took me about an hour.
            Originally posted by copyman
            I wanted to add something very important, I also automatically replace the 2 small bearings on the sponge roller. This will stop any noise from the fuser plus not disintegrate and ruin the sponge roller shafts! bearings available aftermarket or very common used in many Kon/Min models. I take them from finishers that I'm scraping. Example: There are 4 - 6 of these small bearings in a FS-534.
            Most of the bearings on these machines are of international standard. You can find the bearings a lot cheaper for a hardware supplier.
            Whatever
            • copyman
              Owner / Technician
              • Sep 2005
              • 4646
              #21
              Thanks everyone for valuable advices and especially copyman. I have one fuser in hand and would like at least to attempt rebuild it. Then we will see.
              So to sum up I will need belt and lower pressure roller + 2 small bearings, right?
              As for Alibaba/Aliexpress suppliers I have here CET parts available:
              http://www.cetgroupco.com/gb/ and will try them.
              Correct, all you will need is the Fuser belt, LFR & 2 small bearings. All sold at Copylite
              When ever you have a fuser making that weird noise or squeal when sitting idle it's the 2 small bearings on that sponge roller inside the belt. You can change these without dissembling the whole unit. Takes 10 mins each side.
              I've had low volume accounts with under 100k where fusers were making noise, do I replace the fuser for $500+, Hell no! I replace the 2 small bearings! 20 mins of my time and $10 for the new bearings $0 if I take from scrap machines!
              I remember the days working for a dealer and OEM and knicking customers drum, or damaging something else! No big deal just have the company I worked for order a new one. You change your way of thinking (and way more careful) when it's your own money.
              But biggest satisfaction is saving my customers money. Most are like my friends after 20+ yrs of their loyalty to me.
              • tulintron
                • Jul 2014
                • 668
                #22
                Allan, about 40 minutes. The pressure roller cleaning set is removed and discarded. It only serves to decrease the useful life of the fusion. The rest of the merger, we exchange whatever is necessary.
                • allan
                  RTFM!!
                  • 5462
                  #23
                  On the 554 b/w I just throw the cleaning roller out and the fuser end up going past life. So you say even with the color machines its ok to get rid of the cleaning roller?
                  Great stuff. 40min not to bad for saving like $300.
                  Whatever
                  • tulintron
                    • Jul 2014
                    • 668
                    #24
                    Exact. They only serve to reduce service life and bring problems. Our contract equipment is all without the cleaning kit.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4646
                      #25
                      That cleaning kit is basically there for two sided copying. If your customer does a lot of 2 sided best to leave in. Otherwise the LFR roller will get a build up on it that will not come off without destroying the roller. Just have to remember to change the small bearings (same bearings discussed earlier in this thread) and bushings around 100K. Again the cleaning roller is available aftermarket for a lot less than OEM!
                      Just want to be clear with my feelings using OEM, I will only use OEM toners & developers!
                      But finding many aftermarket parts are just as good if not better than OEM. Usually at less than 1/2 the cost. If there is ever a time I find an aftermarket part craps out early or affects quality or operation I will never use that part again. Fortunately only happen once or twice with small parts like feed rollers, etc. Some OEM & aftermarket parts are being made in same factories in China.
                      • Gift
                        • Mar 2011
                        • 2459
                        #26
                        Ricoh has another thought. All fusers, developer units, drums etc need to be rebuilt.
                        Even the electronic boards want them to be sent to the factory for repair.
                        They currently change that for most products except for the production printing models. You can order single parts but a sleeve unit for the IMC series exceeds the price for an entire fuser. Not shure about the boards, never have been askes or offered to send them in but I don't really handle boards regulary, not much issues.
                        I was also tempted in rebuilding some KM fuser units but haven't done it yet. I also like the input about removing the cleaning roller to improve the lifetime - even if I still hesitate to try that out lol
                        • KMFLT3CH
                          • May 2017
                          • 229
                          #27
                          My time is more valuable, 4/5 calls per day, if I was rebuilding fusers that would be halved then 10 calls the following day.
                          Sounds like you and I both work for OEM 😂
                          • DelawareJim
                            • Jan 2008
                            • 65
                            #28
                            Hey guys, just to clarify on the c554 and c554e and 554, are you saying to remove the aluminum cleaning roller and leave it out? Also, are you saying to leave the brush roller in? Thanks
                            • Synthohol
                              Certified Konica Expert
                              • 5807
                              #29
                              I toss out the fuzzy roller and clean the black one with a greeny. (Scotch-brite pad)
                              • L0rdC
                                • Feb 2021
                                • 82
                                #30
                                have you tried cleaning the band with wd-40?
