c364e firmware upgrade
  • afonsolaw
    • Feb 2021
    • 4
    Hi all. Trying to update my c364e. Using a 2gb fat32 USB. Placed the files inside the A61F0Y0 in the root of the USB. When i plug usb into service port (power down machine, insert usb, power up machine.) I get a invalid external memory error. Any assistance appreciated.
    m4RGn096GKt7TyzeMriMJbxLSIcDGoxyvapg3Pm_s1IVEmfPggg9-8RGRe9Lmp4H8V3NiSWLwABHxXajcY02fR7BanNjgmSI.jpg
  • Woxner
    • Jul 2011
    • 850
    Re: c364e firmware upgrade
    Open the folder and transfer all the files in the folder to the root. Nothing else on the usb.
    • afonsolaw
      • Feb 2021
      • 4
      Tried that with mult flash drives.
      • Synthohol
        Certified Konica Expert
        • 5846
        do a system data clear in service mode then try again.
        also just to check, the root of the flash drive looks like this right?
        • afonsolaw
          • Feb 2021
          • 4
          Will try the data clear. Yes. Looks right.
          Thanks as always.
          • Khin Zaw
            • Oct 2009
            • 19
            [ATTACH=CONFIG]48409[/ATTACH]
            I got same shit. Did you get solution to that?
            • techsxge
              • Jan 2022
              • 660
              Reformat the USB Stick with rufus or gparted, not with windows.
              • ltdiniz
                Supervisor de Campo
                • Mar 2021
                • 98
                I use this program for Formatting and it works 100%.
                You can format via cmd as attached step by step.
                Follow Link
                The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
                • adfgdf
                  • Jan 2022
                  • 12
                  As mentioned before,
                  check that the USB stick is formatted in FAT32 and has is up to 8gb storage,
                  leave all the files in the main folder (like D:\ ),
                  make sure it fits in correctly 100% , some times the USB stick doesn't make full/correct contact,
                  check if there is anything inside the machine USB port (protected by the small metal plate), like dust etc.
                  Try several times by pushing it in better, i have seen the same USB stick not working sometimes for it was not making the right contact.
                  Good luck!
                  • copier tech
                    • 8167
                    Does the machine come to ready if you restart the device without the fw USB pen connected ?
                    • Kenny
                      • Jun 2009
                      • 529
                      isnt A61F0Y0 mono machine firmware?
                      latest C364e firmware is meant to be - A5C10Y0-F000-GDR-M1.exe
                      EDIT: my bad i didnt see the OP was back in 2021
                      • emujo2
                        • Mar 2017
                        • 1579
                        Dittos to Kenny..The OP is trying to install the incorrect f/w..Yeah it's an old post, but the OP should have updated it with a "my bad". E
