Bizhub 4050 Prompt A Trouble Code E301(000.00)
  • GeorgeTech
    • Feb 2021
    • 3
    [Error Code] Bizhub 4050 Prompt A Trouble Code E301(000.00)
    I encountered this trouble code when connecting network cable to a Bizhub 4050 network port.
    Could someone help me with a firmware update for this equipment. Thank you.
    E-mail adress : george@clahitech.ro
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: Bizhub 4050 Prompt A Trouble Code E301(000.00)
    4050 or 4050i?
    • GeorgeTech
      • Feb 2021
      • 3
      Bizhub 4050, I can't get over this erorr. Tried everything I could.
      • Synthohol
        • 5847
        tried reseating the memory?
        • GeorgeTech
          • Feb 2021
          • 3
          I have 12 identical printers, 5 of them have the memories soldered on the motherboard, tried formatting HDD, replaced HDD, reset, clear all data, still no result so the last one remains updating the firmware, but I could not find any. so I would appreciate any help provided.
          • copier tech
            • 8172
            We usually see this error on the iseries caused by the Markeplace app or screensaver.
            • tsbservice
              Field tech
              • 8020
              No fancy schmancy Marketplace for those old POS Lexmark boxes.
              • Synthohol
                • 5847
                I help users with firmware if they have a contributor badge.
                • copier tech
                  • 8172
                  Contact us the site below should you still require this firmware.
                  Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
                    • 23009
                    Firmware won't help. The bizhub 4050 is part of the family 4020, 4050, 4750, all of which are susceptible to locking up due to certain network activity. Even if you try to print an internal report, that report stays locked in the queue ... until you unplug the network cable, then it prints.
                    AFAIK there is no known fix. =^..^=
                    • Synthohol
                      • 5847
                      Error
                      Trouble code E301 (Detail Codes 0xB### or 0xC###).
                      Root Cause
                      Firmware anomaly.
                      Workaround/Fix
                      Update firmware to Maintenance Release 8 for bizhub 4050/4750 and Maintenance Release 7 for bizhub C3350/C3850/C3850FS.
                      Technical Notes
                      Please refer to attached Program Release Information documentation for any special instructions. Chameleon documentation is also attached for bizhub 4050/4750 MR8 with Web Browser firmware.
                      • Cantechman
                        • Nov 2008
                        • 228
                        If the error code does not appear, plug in any applicable cables or add-ons one at a time, waiting at least 30 seconds between any additions. If the code appearswhen the network cable is plugged back in, the issue is data being sent over the network. That will be up to the customer and his or her IT professional totroubleshoot as that is independent of the printer and not something we can effectively troubleshoot for the customer. Right from KM.
                        • tsbservice
                          Field tech
                          • 8020
                          Essentially they(KM) tell you to say - " Hey Mr. Customer F..k off! This is Lexy machine and blame them for our decision to put KM logo on it. "
                          • 3ktlc
                            • Feb 2018
                            • 180
                            Yep. We had to replace 2 of these with other machines to save the customer. Left Km soon after at took on Ricoh. Customers are very happy.
                            • tsbservice
                              Field tech
                              • 8020
                              😆 confirmed my suspicions that only Ricoh can beat KM machines.
