i series update firmware
  • jwai
    • May 2018
    • 509
    Hello,
    Do everyone have experience below :
    On normal working i series machine, when I tried to update firmware, it displays black dot with 25% bar.
    After 5 minutes later the machine restarts and displays initial screens ( 25%->50%->copy mode screen ), so I cannot update successfully.
    I checked the admin setting, the USB permission for update firmware is ON.
    Any idea about this issue?
  • francisco
    • Nov 2009
    • 168
    Re: i series update firmware
    Originally posted by jwai
    Hello,
    yes
    storage board defective
    • Synthohol
      Certified Konica Expert
      • 5847
      whats on the flash drive?
      should just be "FW000##" folder.
      just checking because its different than the 4 series tree.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Also, KM has a diagnosis/recovery tool out now that will tell you why the machine is stuck at 25% or 50%. It was in the weekly "One Stop Postings" email today. There is one for every i-series machine out. The middle of the tool name is the same for all of them, although the beginning and ending is different (beginning is the product code, I believe). Look for F000-GXX on KM service portal.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • copier tech
          • 8172
          +1 Yes this is a very useful tool.
          Diagnosis and recovery bootup issue tools.pdf
          • jwai
            • May 2018
            • 509
            Originally posted by francisco
            yes
            since I tried several i series machines ( normal working ), all have this problem.
            Only one machine could do so since the CPUB defective and need to be replaced.
            • jwai
              • May 2018
              • 509
              I check the folder FW00XX and it's correct.
              Only one replaced CPUB machine can be updated, fail on others with normal working status.
              • tsbservice
                Field tech
                • 8020
                This tool does NOTHING
                Tested on 2 stuck at 25% boot C250i. It loads, you press check it will pass all in 2 seconds and gives OK.
                Still new Storage board is required.
                See attached.
                BR
                • Max
                  • Oct 2011
                  • 561
                  Same experience. Tool says all good. Yet doesn't boot up/update.
                  • copyrooks
                    • Oct 2013
                    • 210
                    When i had an issue with an i series unable to get into service mode, the KM tech instructed me to use the tool and also perform a hdd partition which he told me to do a few button presses before applying firmware. The issue got resolved but the counters got lost
                    • HoonBoy
                      • May 2011
                      • 130
                      mind sharing the tool and hdd partition instructions? Would be nice to save an SSD.
                      • emujo2
                        • Mar 2017
                        • 1579
                        Hello,
                        Please list the exact steps you take to put this machine into f/w update mode..I series are different than 8 series. E
                        • copier tech
                          • 8172
                          The process is covered in the service manual. Hold down the button behind the control panel (remove small cover)
                          Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
                          • emujo2
                            • Mar 2017
                            • 1579
                            yes sir, I am aware of the process, if the poster does not mention the button under the cover, we can probably stop trying to help him. E
                            • jwai
                              • May 2018
                              • 509
                              Yup !
                              FAT32 USB stick with F/W folder on root
                              Insert that stick on USB slot on right side
                              Main switch ON with pressing STOP key behind panel
                              Black dot display on top left corner of display with 25% bar
                              After few minutes it took auto reboot and got normal process to copy screen.......
