C224 fax kit
  • jwai
    • May 2018
    • 509
    C224 fax kit
    Hi everyone,
    I have one fax kit FK511, attempt to install on one C224 ( F/W G00-XX ).
    When I restarted the machine, CB003 display during the preparing scan/fax.
    So I check both USB and signal harness and plugged them again, still same issue.
    So I took this fax kit and installed another one C224 ( F/W GD5-XX ), it worked normally without any error.
    What's the reason about it? Thanks.
  • copier tech
    • 8174
    Re: C224 fax kit
    Originally posted by jwai
    Hi everyone,
    With both machines being on different firmware version I'd start updating the firmware on the C224 with the error.
    • emujo2
      • Mar 2017
      • 1579
      Re: C224 fax kit
      It's also very easy to bend the pins on that connector...In my experience most fax codes on install are caused by this..there is also a small switch on the fax board that configures if for fax 1 or 2..Ensure it's set to 1. E
      • jwai
        • May 2018
        • 509
        Re: C224 fax kit
        This fax kit had been removed from a C364e fax 1 slot.
        • emujo2
          • Mar 2017
          • 1579
          Re: C224 fax kit
          well maybe you should not have posted that both machines were C224s..There is a big difference between the 2..I now support the inco firmware on the fax board. E
          • copyman
            Owner / Technician
            • Sep 2005
            • 4723
            Re: C224 fax kit
            Even if machine has error code you can wait awhile and eventually enter service mode. Compare setting between the two machines. Also can initialize the fax unit in service mode.
