Bizhub 808
  • antone
    • Oct 2014
    • 344
    Bizhub 808
    Trouble code 808 ..C 3102 ..updated firmware..replacement of fuser drive motor M3 and pressure release lever....also tried another fuser!
    Sent from my SM-N981U using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: Bizhub 808
    i bet i know what it is!!
    the belt fell off the duplex motor.
    add a shim like i did to the lower corner.
    [edit] i may be thinking of j3102, i dont remember now. dammit![/edit]
    • copier tech
      • 8227
      Re: Bizhub 808
      • Code: C3102
      • Description:Heating roller failure to turn. During any state other than printing operation, the hard latch signal from one or both of the heating roller rotation latch detection 1 and the heating roller rotation latch detection 2 is turned ON.
      • Causes:Remedy:
        • 23010
        Re: Bizhub 808
        For me, its always been the eight pieces of paper accordianned in the fuser exit, that the enduser doesn't notice. It stops the fuser drive. =^..^=
        • tsbservice
          Field tech
          • 8068
          Re: Bizhub 808
          Eight because it's 8 series or because it's bizhub 808
          • tulintron
            • Jul 2014
            • 668
            Re: Bizhub 808
            A simple question, but it can solve:
            Did you perform the trouble reset?
              • 23010
              Re: Bizhub 808
              Yes, exactly. =^..^=
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1257
                Re: Bizhub 808
                Sounds like you've done all the logical steps----- If replacing the fuser unit and fuser motor and then running the trouble reset did not fix the issue, I would suspect something is bad in the fuser drive unit assembly.
                • antone
                  • Oct 2014
                  • 344
                  Re: Bizhub 808
                  C 3102 not J 3102 ...fuser Lever under M30 no getting being pushed in from vertical transfer door!
                  • Synthohol
                    • 5908
                    Re: Bizhub 808
                    oh crap, i had that too, i added labels to the switch for thickness to get it to fully engage.
