Finisher disappeared
  • jwai
    • May 2018
    • 509
    Hello,
    I have one 654e that FS-534 finisher had been installed.
    The customer reported paper jam, I found the stapling option has been disappeared in finishing mode.
    Now I disassembly the FS and RU for temporarily use, this issue caused by the finisher board or the harness to the copier?
    Best regards,
  • tmmdmmm
    • Apr 2021
    • 173
    Re: Finisher disappeared
    Originally posted by jwai
    Hello,
    Best regards,
    When you open the front door it should show the entire machine and any accessories installed. If it only shows the 654 and not the relay or finisher, either the wiring is bad or (more likely) the finisher control board is bad.
    Thats assuming the jam is happening at the first tires of the RU
    • emujo2
      • Mar 2017
      • 1579
      here's what is probably happening. The stapler had an issue that the machine based as a problem, but not catastrophic. The user was asked if they wanted to continue using the machine w/o the staple option, if so push the power save button (or something like that). The machine now reboots with stapler disabled. If this is the cause, then every time you cycle power it should go through the same sequence of events again. The power off/on tells the machine you fixed the issue, bring the stapler back, if you didn't fix it you get the previous message and the cycle repeats. If this is not the case then you should be getting a staple error/service code (unless someone disabled the stapler is service mode. There are no KM finishers that do not have stapling capability. Not speaking of the A4 line. E
      • Gab
        • Aug 2015
        • 671
        Hello,
        Best regards,
        no connection finisher with machine. Perhaps a wire from connector is moved
        • albemero
          • Apr 2019
          • 37
          We had the same problem. It was the finischer-board.
          • tmmdmmm
            • Apr 2021
            • 173
            Got an update? Just looking for future reference if there's anything but the FS board I and others mentioned
            • jwai
              • May 2018
              • 509
              I ordered one FS board and waiting for delivery.
              • jwai
                • May 2018
                • 509
                The machine figure doesn't have finisher showed, I guess the FS board may be defective.
                  • 23009
                  If the cable from the bridge to the finisher is unplugged, then replugged in live it will blow the bridge board or the finisher board. I had a customer that moved around a bunch of machines, but could not seem to find the power switches. =^..^=
                  • Synthohol
                    Certified Konica Expert
                    • 5848
                    ^^^^^^^^^^+1^^^^^^^^
                    • rrrohan
                      • Sep 2011
                      • 1977
                      ive had C754 totally forget it even had a finisher after waking up from power save.
                      if you reboot with full power off then on it works again
                      • femaster
                        • May 2011
                        • 1514
                        I'm not the OP, but the 4 times we've had this happen on this model finisher, every time was a bad board in the finisher. Nothing looked fried, and the fuse was still intact on all of them, so no idea what it was that failed on any of them.
