KM bizhub C250i - C360i printing heavy papers in the graphic market
  • Gift
    • Mar 2011
    • 2444
    #16
    Re: KM bizhub C250i - C360i printing heavy papers in the graphic market
    Originally posted by konicavod
    Reverse AA2J592600 Gear 42T
    KEEU_BT2111154EN
    Thanks - I think we installed the sep roller assy from C308 series wich has way less torque (not shure if that's the content of the bulletin).
    Just got a feedback that the bypass does work like a charme.
    • barber782
      • Aug 2011
      • 279
      #17
      Originally posted by Gift
      +2 - xx4e series was neat, xx8 was ok, xx0i is only ok for office print.
      Currently I have an open call with bypass/thick paper issues (no feed), we try and modify it with different rollers.
      Didn't knew that marketing flyer, sooo funny I almost pooped my pants
      __________________________________________________ __________________________________________________ ____
      Had the same issue today feeding 300gsm through the bypass tray on a 250i. Brand new machine and does not feed at all.
      There appears to be too much pressure applied to the separation roller assembly.
      The only way i could get it to feed was to cut the sprint in half, set to thick 4 and after that it feeds beautifully.
      I can imagine it might have a negative effect on plain 80gsm, but for this customer they only printed 300gsm from that tray, so no biggy.
      • Ziggy
        • Feb 2018
        • 680
        #18
        See attached
        • rrrohan
          • Sep 2011
          • 1977
          #19
          Originally posted by Markks
          See attached
          or install a 4/8 series separation roller if you dont have the spring
