Bizhub C550 Error. This is invalid card. Please make sure the card.
  • copier tech
    • 8161
    [Misc] Bizhub C550 Error. This is invalid card. Please make sure the card.
    Hi all,
    Don't laugh but I have a colleague who needs to update the firmware in order to enable the life stop setting but he get this weird message.
    Have tried 2 different CF cards using the firmware updater tool gives the same message.
    • 14740
    Re: Bizhub C550 Error. This is invalid card. Please make sure the card.
    Hi all,
    I know it an old box but any ideas!? [ATTACH=CONFIG]49569[/ATTACH]
    You may need to use the firmware imaging toolkit to write the CF card.
    • and
      • Oct 2011
      • 96
      For disable life setting in C550 the firmware to use are A00J0Y0-F000-GJ0-F9.exe are you writing this version in the CF?
      • copier tech
        • 8161
        We are trying to update using the latest mass production firmware A00J0Y0-F000-GB1-R6.exe using the firmware imaging tool kit.
        • Albonline
          • Sep 2008
          • 1151
          Check to make sure there are no dos partitions on the cards , you may need to use a Linux disk formatting tool.
          • rrrohan
            • Sep 2011
            • 1977
            Could use ISW instead. I use to do that when I forgot my card or card reader
            Sent from my Pixel 4 XL using Tapatalk
              • 14740
              The card can't be any bigger than 256mb.
              Use the toolkit to format the card before writing it.
              • Synaux
                • Mar 2012
                • 1224
                Are the only cards that I know that work for sure.
                My files show "C650_A00H0Y0-F000-GS6-R6" for IU reset. I am not sure the latest base FW has the IU bypass integrated, but I think it does.
                HTML Code:
                Solution ID TAUS0630235EN* Solution Usage 12DescriptionPart number for the 128MB Compact Flash card which is used to install main body firmware.SolutionCompact Flash card (p/n 7660403601).CAUTION : CF card cannot be larger than 256MB; 512MB will not allow the download to begin. Please see attachment.
                If you formatted the card, you might as well get brand new card... There are workarounds, but it is complicated and I honestly forget exactly how to do it. The info is somewhere in my old posts around here somewhere... lol
                Do you need to the toolkit software?
                Worst case scenario, I could send you a pre-loaded card, but you are on the other-side of the pond it seems. Other other worst case scenario is to simply rechip the IUs--let me know if you need help with that.
                • Zesti
                  • Jun 2009
                  • 308
                  Hi all,
                  What firmware updater you are using?????What capacity cards did you use?..... as advised above use 128MB or 256 MB cards
                  • Synthohol
                    Certified Konica Expert
                    • 5829
                    There is a program called HxDen that will write zeros to the whole card returning it to factory fresh with no file system or format.
                    • Synaux
                      • Mar 2012
                      • 1224
                      That is cool!
                      • Synthohol
                        • 5829
                        thought id follow up with the app and bulletin.
                        • srvctec
                          Former KM Senior Tech
                          • Oct 2009
                          • 827
                          Thanks for this since I couldn't find it anywhere to download.
                          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                          • copier tech
                            • 8161
                            Thanks all for the help we resolved this issue with a 3rd CF card (128mb)
