C454E
  • fearless
    • Jun 2015
    • 20
    C454E
    Enter the serial number for scanner
  • Thib
    • May 2017
    • 35
    The MFPB... specifically, the battery (yellow wrapping). We have had success soldering a new one on, but less success retaining the meter counts (about 50/50 on that front).
    • Synthohol
      Certified Konica Expert
      • 5813
      if you take off the covers around the platen glass the scanner serial# is on a sticker on the metal frame..
      could be the battery for sure but i just wanted to point out where the scanner serial tag was.
      • fearless
        • Jun 2015
        • 20
        Thanks for your feedback. The meter count has been reset to 0 and none of the trays are available. I updated it 3 days ago with GDH-M1 which is a base firmware.
        • Ziggy
          • Feb 2018
          • 709
          If all counts are zero and its asking for serial number input then the battery is dead on the MFPB. Time for a new MFPB or the very least a new battery then you will have to set machine up as it is new. Good luck, just in case you didn't know this machine is obsolete so getting oem parts and supplies are going to be very difficult . It time to upgrade.
          If you try to revive this one you will probably need the board reset file after replacing battery
          • fearless
            • Jun 2015
            • 20
            Thank you for your diligent expertise.
