Konica 308e A4R copy/scan problem
  • ferro10
    • Jun 2015
    • 117
    [Misc] Konica 308e A4R copy/scan problem
    Hi everyone
    A client of mine with a Konica 308e signals me with a decidedly anomalous problem.
    When it makes a copy/scan in A4R they are completely moved.
    I checked the user settings and there is nothing out of place do you have any suggestions?
    see attached photos
    This gallery has 3 photos.
  • Synthohol
    Certified Konica Expert
    • 5878
    1, make sure A4 shows up on the screen as the detected size.
    2, use the square box calibration page on the feeder for stop position adjustment.
    3, ( should have been first) make sure the copies off the glass are centered/registered properly, then see #1
    4, Good Luck.
    • ferro10
      • Jun 2015
      • 117
      4, Good Luck.
      Thanks for the suggestions, unfortunately I don't have the scanner calibration sheet you know where I can find it?
      • Synthohol
        • 5878
        comes with every copier with the documentation. (that has a feeder i mean)
        part#
        A782945000
        im sure there should be one at any of the machines you service.
        oh, fwiw its an ADF calibration sheet, scanner calibration is a whole other PITA ordeal
        only mentioned it in case you do a search for it.
        • ferro10
          • Jun 2015
          • 117
          With Konica Minolta we only deal with used printers and arrive without this sheet.
          I proceed with the order of the calibration sheet then I try with the suggestions above.
          • tsbservice
            Field tech
            • 8042
            Originally posted by ferro10
            Hi everyone
            see attached photos
            What about a4r from platen glass?
            If that's ok i would suggest doing adf recalibration as Synthohol mentioned.
            • Synthohol
              • 5878
              i was wondering what an AI bot sounds like on a wednesday, now i know ^^^^^^^^
              • ferro10
                • Jun 2015
                • 117
                I solved
                I regulated the setting "original tray width"
                thank you all
                  • 23010
                  Congratulations on your success. =^..^=
