Klack klack klach... from Heater C-224e
  • CP-1015
    • Nov 2020
    • 323
    Wasn't there a thread because of knocking noise from heating drive? Thanks advanced.
  • tsbservice
    Field tech
    • 8020
    It's either fuser itself(most likely) or fuser drive.
    What is the total count?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Yes, 4 & 8 series fuser noise has been discussed on this forum many times but might not be able to find with this new website. 99% of the time the noise is from worn fuser bearings and happens even when machine is idle. Aftermarket bearings / parts are available to rebuild this fuser but it's not an easy fuser to rebuild.
      • CP-1015
        • Nov 2020
        • 323
        Thanks to tsbservice and copyman. Total count is less than 180000. Next time I'll test a rebuild fuser. Noise is when machine is idle.
        • femaster
          • May 2011
          • 1514
          Not sure if you have had any jamming issues in addition to the noise, but CL8 in the fuser drive unit is a known problem, even at low volume. They make noise and prematurely wear out. One of the more common signs of issues with this clutch are a rust powder near the hinge area of the transfer/duplex unit. If you can see the rust powder there, the clutch is already in an advanced stage approaching failure. In early stages, you might see some powder on the drive gears or the clutch body itself, but you would need to remove the upper rear panel to see this.
          • CP-1015
            • Nov 2020
            • 323
            No issues only noise. And I cann't believe that bearings makes every second klack. But I changed heater and noise is gone. Next days I'll change the 4 small bearings. And test again.
            • tsbservice
              Field tech
              • 8020
              I bet small bearings will cure it. You can get KM OEM from another model. PM me if you need PN.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4723
                [QUOTE=femaster;n1566948]Not sure if you have had any jamming issues in addition to the noise, but CL8 in the fuser drive unit is a known problem, even at low volume. They make noise and prematurely wear out. One of the more common signs of issues with this clutch are a rust powder near the hinge area of the transfer/duplex unit. If you can see the rust powder there, the clutch is already in an advanced stage approaching failure. In early stages, you might see some powder on the drive gears or the clutch body itself, but you would need to remove the upper rear panel to see this.
                image.png[/QUOTE
                Agree CL8 is very common issue but usually for jamming not noise when idle. By the way there is a short cut procedure to replace this clutch. I can post if anyone wants it.
                • Hansoon
                  • Sep 2007
                  • 3389
                  Yes, please!
                  Hans
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4723
                    Attached is shortened version to replace CL8 fuser exit clutch.
                    • CP-1015
                      • Nov 2020
                      • 323
                      Now 4 new small bearings 688ZZ with flange. Fuser is silent! Thanks all.
