Bizhub C3350 vertical lines in the center of the printed page
  • kombo2
    • Oct 2018
    • 16
    On some prints there are grey or black vertical lines (see scan), does anyone know what might cause this problem?
    vertical stripes(small).pdf
  • copyman
    Owner / Technician
    • Sep 2005
    • 4623
    Re: Bizhub C3350 vertical lines in the center of the printed page
    [ATTACH]49702[/ATTACH]
    Looks like black image unit or transfer belt need to be replaced. What do the consumable life counters look like?
    • tsbservice
      Field tech
      • 7975
      +1 on black IU.
      • robinsonad86
        • Aug 2014
        • 67
        Take the TBU out of the machine and turn by hand if the marks disappear off the belt then its black image unit
        • kombo2
          • Oct 2018
          • 16
          Thanks for the suggestions, i should have mentioned that i have replaced the black imaging unit just a couple of weeks ago because of another issue (that was fixed by the replacement), so i hope it is not the imaging unit again.
          • tsbservice
            Field tech
            • 7975
            What was another issue?
            • kombo2
              • Oct 2018
              • 16
              Consumables are pretty ok, that unit is used only very lighly.
              • kombo2
                • Oct 2018
                • 16
                https://www.copytechnet.com/forums/k...tml?highlight=
                I think you even helped to solve it : )
                • copiray
                  • Feb 2019
                  • 29
                  By the color of the stripes and the distance between them, I would say that it is a problem with the transfer belt, check manually
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    I agree.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • kombo2
                      • Oct 2018
                      • 16
                      Last time i made some pictures of the belt, is anything visible in these pictures? I can see some scratches but can not judge if they might be causing these vertical lines.
                        • 22997
                        The color of the marks indicates primary transfer cleaning. Note the color of the streaks:
                        C:6
                        M:3
                        Y:0
                        K:23
                        • femaster
                          • May 2011
                          • 1482
                          The lines seem to vary in width, so my guess is the Trans Belt not getting cleaned properly. Remove and check to see if something is caught in the cleaning blade / unit. Clean it out if there is, and you might solve your issue with no parts. If the belt is near life, probably best to just replace it anyway as the problem would most likely return.
                          • Walterj
                            KONICA MINOLTA
                            • Jun 2017
                            • 89
                            Good day
                            Estimated according to your scan it is visualized that these marks are from the leading edge of the paper and it is very likely that it is your black imaging unit.
                            I recommend you take the halftone test at 128 for each color so that you can see the most accurate error.
                            Lucky.
                            • copiray
                              • Feb 2019
                              • 29
                              belt.jpgbelt2.jpgbelt3.jpg[/CITA]
                              If the problem is in the transfer belt, it will be in the cleaning blade, check if it has accumulation of dirt in the area where the paper stains, the use of poor quality paper produces a lot of paper dust that ends up on the cleaning blade , the band seems to be fine
