Foggy PH Protective Cover
  • inutelkamo
    • Jul 2011
    • 143
    Hi Masters,
    Any suggested remedy for this?
    PH protective cover was foggy. (see the upper part of the image). Laser cant penetrate well, creating a uneven image from lead to trail.
    The fog seems to be on glass can be remove by wipes.
    Parts replacement still not yet to arrive, and looking for possible remedy.
    Option 1.) Remove the protective cover
    Option 2.) Replace the glass from glass sellers
    Option 3.) Abrasive cleaning like in car headlights
    Your thoughtful comments and suggestions are very well welcomed.
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Foggy PH Protective Cover
    kind of reminds me of the analog days and the mirrors would get the same effect.
    this film that nothing in most toolbags have would remove.
    we used to use industrial strength commercial grade windex. https://www.lowes.com/pd/Windex-128-...B&gclsrc=aw.ds
    or try ammonia, blanketwash, vinegar, buffing it with fuser oil. (separately of course)
    those used to help me 20 years ago
      • 23009
      Originally posted by inutelkamo
      Hi Masters,
      [ATTACH=CONFIG]49726[/ATTACH]
      Did you say that it CAN be removed with wipes? Then you're done. In a dirty environment you may need to repeat that periodically.
      Or did I read that wrong? =^..^=
      • REGSIS
        • May 2016
        • 435
        I did read the same.
        • Gift
          • Mar 2011
          • 2459
          Is it moisture? If it can be removed I guess it wouldn't make much sense to swap the glass.
          • inutelkamo
            • Jul 2011
            • 143
            wahaha!
            sarry, typo error..
            i mean, CANT REMOVE by wipes..
              • 23009
              What chemicals have you used?:
              Orange oil based solvent?
              Alcohol?
              Paraffin Lamp Oil?
              WD40?
              I wouldn't much worry about removing any coating from the glass, especially if it's the coating that's discolored.
              It makes me wonder if there isn't an environmental factor, some airborn solvent attacking the coating, or even etching the glass.
              If you cannot get that glass clean, your two options are new glass or new laser. I don't see a model number in the thread ... these look like laser slit glasses on the color presses (much much cheaper than buying whole lasers).
              • Brett GS
                • Jun 2013
                • 154
                Alcohol?
                Paraffin Lamp Oil?
                WD40?
                Looks like B920 glasd that slids into the ph.
