Bizhub C3350i etc PF-P20 installation manual
  • D Colour
    • Oct 2008
    • 213
    [Misc] Bizhub C3350i etc PF-P20 installation manual
    Would anyone have a copy of the installation manual for the additional paper tray PF-P20 (Or PF-P21).
    For the love of me I can't find it on Knova. Assume they just come with a new tray. Have a used tray we can't seem to get to work and I'm sure/hopeful its something simple or stupid!
    Everything that has a beginning, has an end.....
  • copyman
    Owner / Technician
    • Sep 2005
    • 4542
    Can't you use the P21 or P25 install manuals? Should be the same? They are available on Kon/Min dealer website. I have these instructions if you need them.
    • D Colour
      • Oct 2008
      • 213
      Thanks copyman. Could you send me it or upload please?
      When I search Knova it only finds a couple of bulletins and firmare updates.
      • tsbservice
        Field tech
        • 7924
        D Colour, here you are:
        • D Colour
          • Oct 2008
          • 213
          Thanks tsbservice
          So it turns out there is nothing to be done, other than fitting the tray. I was hoping a software switch needed enabled or something. Will need to check the plugs, wiring now! ?
          • Synthohol
            Certified Konica Expert
            • 5740
            you did plug in the wire harness right?
            ive seen this overlooked too many times.
            • tsbservice
              Field tech
              • 7924
              Maybe option isn't exactly compatible with your machine. Konica has an history with that and many techs fell in that trap. I would triple check config guide before doing something fancy ?
              • rrrohan
                • Sep 2011
                • 1977
                It goes Machine -> PFP20 -> PFP22 -> DK-P04
                or Machine -> PFP21 -> PFP25 -> DKP05
                • D Colour
                  • Oct 2008
                  • 213
                  Thanks for the help all. Turned out it was a blasted bent pin!
                  • Woxner
                    • Jul 2011
                    • 829
                    PF-P21 compatibility.
                    After going through the initial setup process, the printer needs to be connected to the network and perform the setup wizard. This is required to make the PF-P21 work. By doing this procedure the printer will then connect to the server and do the necessary update. Once completed PF-P21 will be recognized.
