Konica Minolta bizhub C224 jam code 3205 only from tray 2
  • tsbservice
    Field tech
    • 8013
    Originally posted by Tech09
    ....The success of this site is due to techs helping fellow techs
    True.
    ...not attempting to belittle others and flex your epeens.
    Way too patetic.
      • 8144
      Originally posted by tonerland
      Firstly the size in Tray 2 was A3 , and was same problem, after this I change it to A4 like Tray 1 - the problem is the same. Now the settings in both Trays are same - A4. Jamming only from Tray 2 and pick up rollers doesn't stop to rotate. From Tray 1 and Bypass there is no problem.
      OK, so if you just load just one sheet in tray 2 will it print / copy OK with no jam ?
      • Tech09
        • Apr 2020
        • 145
        To answer your question, he's already replaced the clutches and sensors for tray 2. First I would replace all three tires and clean the one-ways in tray 2 and make sure the double feed prevent assembly is working properly, replace PS19, reseat the connectors on the PRCB, reflash firmware and if none of that resolved replace the PRCB. It's stream feeding, so either the DFPR is shot, which he already replaced, the feed clutch is shot, which he already replaced, or the clutch is just not receiving its signal to turn off, PS19 not working or the PRCB.
        • Alertbex
          • Apr 2024
          • 2
          #19
          Hi guys,
          i solved this jam by checking this sensor :
          on Olivetti MF 459
          Hope this can help some of you
          This gallery has 1 photos.
