Konica Minolta bizhub C224 jam code 3205 only from tray 2
  • tonerland
    • Oct 2022
    • 22
    Hello! I have issue with one bizhub C224 which jammed only from tray 2 - jam code is 3205. I see that pick up rollers doesn't stop rotating. When I try to print 1 copy it comes 4 sheets one after one. I think that this is the main problem - pick up rollers, doesn't stop to rotate. I change all the sensors and clutches in paper feed drive mechanism and the problem still persist. Any ideas where the problem is?
  • copier tech
    • 8200
    DO you have the same paper size is tray 2 & tray one ? if not swap the paper round & see if the fault moves.
    J3205 is an exit jam so the paper has passed pick up.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4765
      Just to be clear you removed the complete paper feed unit and replaced the tray 2 mag clutches on back of unit?
      • tonerland
        • Oct 2022
        • 22
        Yes, thats right.
        • JMS
          • Apr 2023
          • 30
          Did you check the paper exit sensor (PS3, in reversal unit on top of right door)?
          Perhaps the paper exit clutch (CL8, in fusing drive) is rusty.
          • Massimiliano
            • Oct 2019
            • 48
            Good morning,
            I solved the problem with jam 32-05 on many machines by replacing the gate switch solenoid. (A161R72644)
            • rrrohan
              • Sep 2011
              • 1977
              also check these out
              • tonerland
                • Oct 2022
                • 22
                Thanks to all, this days I will go to customer and try this things, but I see no logic in any of this to keep the rollers spinning incessantly.
                • rrrohan
                  • Sep 2011
                  • 1977
                  dont fix whats no longer broken
                  • elmaligno
                    Expert technician KM
                    • Oct 2009
                    • 302
                    I agree with you, it is important to know, that you do not say, if in both drawers the paper is the same size and placed in the same position.
                    Field technician since 1994
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4765
                      Coper rule # 1 , there is no "logic" with copiers. You have been provided some good FREE info, do what you want with it.
                      FYI, a dirty or bad clutch will keep rollers spinning, seems logical to me......
                      • tonerland
                        • Oct 2022
                        • 22
                        Firstly the size in Tray 2 was A3 , and was same problem, after this I change it to A4 like Tray 1 - the problem is the same. Now the settings in both Trays are same - A4. Jamming only from Tray 2 and pick up rollers doesn't stop to rotate. From Tray 1 and Bypass there is no problem.
                        • Larhal
                          • 616
                          Tonerland, your a lost cause. The answers were given to you but you refuse to listen or act upon them.
                          Larhal
                          If all else fails read the Service Manual!
                          If that fails, meet me at the pub and we will discuss it.
                          • Tech09
                            • Apr 2020
                            • 147
                            A little harsh don't you think?
                            His issue has nothing to do with the exit unit or solenoid or linked pdf, it's stream feeding from tray 2. Copyman is the only one who even came close to trying to help with the issue as described. The success of this site is due to techs helping fellow techs, not attempting to belittle others and flex your epeens.
                            • tsbservice
                              Field tech
                              • 8052
                              So what do you think his issue is?
                              I don't see your point coming and delivering only justice upon what.
