Bizhub c658 white spots on color prints
  • cyborgenius
    • Oct 2022
    • 5
    bizhub c 658 white spots on color prints
  • Synthohol
    Certified Konica Expert
    • 5808
    is that a question?
    where's the sample pic?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4652
      FYI, there are some great techs on this forum but none are mind readers! Besides providing pics how about some other details like meter count, consumable life counts & what you have done so far? This will help get you help much faster.
      • rrrohan
        • Sep 2011
        • 1977
        thats like going to doctor and only saying "im sick"
        • tsbservice
          Field tech
          • 7998
          He is a genius so what do you expect
          • cyborgenius
            • Oct 2022
            • 5
            Hi jip sorry used to the old site where you type key words and possable solutions came up
            Nevertheless
            Consumables on the c658 are original average of 50%life on all drums and dev and transfer belt and roller I have adjusted fuser temp and speed and transfer voltage strange enough on A4 bond the spots are not there but appear on A3 bond and thick2 Matt
            This is on all cmyk
            Image on transfer belt is perfect
            But once transferred it shows white spots so I stopped transfer roller from another mc same thing happens
            Humidity in mc is at 12 true Humidity is at 2 inside temp 26 degrees C
            I wiltry and upload a image
            • cyborgenius
              • Oct 2022
              • 5
              Halftone cyan pattern density 255
              • tsbservice
                Field tech
                • 7998
                Did you tried Charge AC Output fine adjustment, Primary transfer adj. and 2nd Transfer Adj.
                • cyborgenius
                  • Oct 2022
                  • 5
                  Problem solved it turned out to be the transfer belt does not make sense but it solved the problem
                  • tsbservice
                    Field tech
                    • 7998
                    But you've said image on ITB is perfect... apparently not so much.
                    • Tech09
                      • Apr 2020
                      • 144
                      Your problem could still be with the 2nd transfer roller though, the new itb could just be masking it for now. As tsbservice mentioned, Image Process->Transfer Voltage Fine Adj->2nd Transfer Adj
                      • cyborgenius
                        • Oct 2022
                        • 5
                        Hi ok if you read my post i stated that i have adjusted transfer voltages and that it only appears on A3 and Thick 2 Matt paper i also changed the transfer roller,not have much this did not have much effect on the spots
                        therefore after changing the itb it solved the problem propebly some thing to do with charge on long transfer and thick transfer
                        thnks for all your possitive feedback
