KM C658 HDD Lock password
  • apn821
    • Nov 2021
    • 5
    [Misc] KM C658 HDD Lock password
    I have a C658 with a "Rest HDD Lock Password" display. I've tried the serial # but that doesn't work. I know there is a specific set of numbers that have to be input along with some 0s.
    Hopefully someone can help me out with this. Otherwise, I have to replace the HDD.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4639
    See attached. I've used this password & procedure several times successfully for the 4 series. DSCF2517[1].jpg
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      The solution is easy, extract the HDD, mount it in a PC, delete the partitions and leave it formatted in FAT 32. You put it back in the machine and it will tell you that the disk is not formatted, that it is necessary to format it, you say yes, you do the logical formatting and in a minute you have it ready.
      Field technician since 1994
      • Ziggy
        • Feb 2018
        • 693
        Just do a physical format in service mode, then logical format. it takes a while but it will get rid of hard drive lock password error. You will need to reload movie data
        • copyman
          Owner / Technician
          • Sep 2005
          • 4639
          The easiest way to solve this is try that long password in my previous post. For some strange reason it works!
