Very Old BH-350 with DF-605 ADF
  • Hansoon
    • Sep 2007
    • 3385
    I donated years ago to a nonprofit organization, a Bizhub-350 mono MFP. The machine has very little on the clock, so for them still of real value. Now it developed an annoying problem which I myself have never seen by this generation before. Copying from the platen is perfect, but when using the ADF the printout moves around 5 cm sidewards in the scan direction. See attachment.
    Any idea what could be the cause?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5840
    calibrate the ADF in service mode with the black box chart.
    • Hansoon
      • Sep 2007
      • 3385
      Yes, I recall seeing about that somewhere, but could not find in the DF-605 Installation Manual nor the tech manual anything about it. Thought it was for the later generations.
      Hans
      • copyman
        Owner / Technician
        • Sep 2005
        • 4712
        Hi, Attached are a few things I found in my old notes. Might not be exactly what is happening in your case but would still keep the BCRS board in mind. *FYI the BCRS board is different between 200/250 and the 350
        • Synthohol
          • 5840
          bh350df.pdf
          hope the machine still has the chart
          • copyman
            Owner / Technician
            • Sep 2005
            • 4712
            Hans, I have several Biz 200 series with good DF605 getting closer to the door to throw into dumpster. Let me know if you need anything from them. Also may have a 350 if you need the BCRS board.
            Free, just pay shipping. Take care
