Bizhub C3110 shows replace k toner
  • copier tech
    • 8142
    [Misc] Bizhub C3110 shows replace k toner
    As the title says i'm fighting this issue, machine displayed empty K toner I replaced with a new one but the message remains.
    I took out all the toners & IU's cleaned all contacts, updated the firmware no luck.
    No Idea how to proceed with this one!?
    • 23007
    Re: Bizhub C3110 shows replace k toner
    What have you done so far? =^..^=
    • tsbservice
      Field tech
      • 8007
      Black toner was empty indeed before replacement? Whaf about consumables life?
      • copier tech
        • 8142
        • copier tech
          • 8142
          Yes the first K toner was empty so fitted a new one, message didn't change.
          I can't print off the IU life consumable counter list with the empty K toner message so I was wondering if the K IU was at end of life could this stop the K toner empty message from clearing?
          • tsbservice
            Field tech
            • 8007
            I would try to use ENGINE DIPSW 28, set this to 1 to force clear toner empty state, then return it to 0.
            At first you will need to enable ENGINE DIPSW via soft switch 59, set this to 1.
              • 23007
              Can you manually trickle some toner from the new cartridge, by turning the coupler? Some of the seal may remain, or the drive may be broken, or the toner may be fused in the toner cartridge. I think I'd start there before looking at the machine, especially if it consumed the previous cartridge correctly. =^..^=
              • REGSIS
                • May 2016
                • 435
                Possibly yes, but any other error/jam can also prevent K toner empty from clearing.
                I had a case like you. Customer was also pulling out the fuser and didn't put it back all the way in (back side). Somehow the door was closed (front side).
                I had to re-seat the fuser first, and then toner empty was cleared.
                • memet
                  • Jan 2016
                  • 12
                  Can you spin the toner bottle yourself?
                  Sent from my MI 9 using Tapatalk
                  • copier tech
                    • 8142
                    • copier tech
                      • 8142
                      Yes I can easily turn the K toner bottle.
                      • bazylius
                        • Jun 2021
                        • 2
                        Replace chip, should be fine.
                        Some customers touch chip when they`re changing toner. Its only 63mA i think
                        Love plastic floor and wool sweater...
                        • byronf
                          Senior Member
                          • Sep 2017
                          • 109
                          Hi,
                          This is a region issue, what are he first four digits of the serial number of your machine?
                          • mattcoop11
                            • Jun 2015
                            • 12
                            • copier tech
                              • 8142
                              I sent this client a new set of toners this seems to have resolved the issue. Thanks all.
