Bizhub C3110 shows replace k toner
  • allan
    RTFM!!
    • 5462
    #16
    Re: Bizhub C3110 shows replace k toner
    Originally posted by byronf
    Hi,
    This is a region issue, what are he first four digits of the serial number of your machine?
    Had this before on a C35. Not sure if the C3110 use a 6pin chip or only a fuse to rest the count. Recall replacing the fuses to reset the toner count.
    Whatever
    • copier tech
      • 8188
      #17
      They use a chip, they look a bit like the ones on say the C224 drums.
      • Hansoon
        • Sep 2007
        • 3391
        #18
        Had one yesterday, a BH-C-3110, calling suddenly for magenta replacement though the cartridge was still halffull. Had to replace the chip.
        BTW: The fuse on the chip can be tricked out with a standard picofuse. The cartridge has to be cut out a little to make room for the fuse.
        Hans
        • jwai
          • May 2018
          • 513
          #19
          I would try to use ENGINE DIPSW 28, set this to 1 to force clear toner empty state, then return it to 0.
          At first you will need to enable ENGINE DIPSW via soft switch 59, set this to 1.
          As I checked C35 too, however it seems don't have.
          • jwai
            • May 2018
            • 513
            #20
            BTW, toner chip for C3100P can be used on C3110 and work properly?
            • Synthohol
              Certified Konica Expert
              • 5857
              #21
              • Sysco
                • Mar 2010
                • 43
                #22
                I have same problem earlier, and I don't know the right answer.
                I changed the toner to another and it's gone.
                I think the KM and Develop toner made in same place just only the chip is
                different.
                So I think it's not an KM toner it's a develop and thay not compatible.
                Try to change toner to original KM toner, but it's not garantie, bacause
                I remember when i run this problem the package is same to the original.
                So change toner and be hope.
                • Oystercopy
                  • Oct 2009
                  • 623
                  #23
                  I've had this issue on MANY machines and have performed all the suggested settings/changes and what not. New Toner cartridge ALONG WITH a new Black IU, softswitch forced to Clear, etc, etc.
                  Nothing has ever solved this issue for me and I've had to trash machines as a result.
                  I suspected that maybe this was a Low Voltage Power Supply issue, where the 5v logic line might be low, but no one has ever confirmed or denied that.
                  It would be nice to know if someone has actually found the ROOT CAUSE of this K Toner issue and let the rest of us know.
                  OC
                  • Old_Tech
                    • Apr 2022
                    • 10
                    #24
                    OC
                    I have had this problem myself and it was resolved by allowing the New Release by User replacement. By default it is set for Service reset only.
