Konica Minolta bizhub C224e replace MFP board
  • Arko289
    • Aug 2021
    • 6
    [Dead] Konica Minolta bizhub C224e replace MFP board
    Greeting. The old MFP board was damaged and I bought a used one. Do i have to put firmware in it or just install it in the device? The SSD and print control board remains old.
    Konica Minolta bizhubC224e
  • tsbservice
    Field tech
    • 8013
    Re: Konica Minolta bizhub C224e replace MFP board
    You will need FW and Reset tool PLUS following the exact procedure.
    • Arko289
      • Aug 2021
      • 6
      Thank you.
      Where I can find firmware?
      Already have Reset tool
      • avecosat
        • Jun 2012
        • 305
        www.copierfirmware.co.uk
        Copier tech will help you
        • escalante
          • Sep 2018
          • 115
          Originally posted by Arko289
          Thank you.
          Good morning. What firmware version do you need?
          Enviado desde mi Infinix X692 mediante Tapatalk
          • Arko289
            • Aug 2021
            • 6
            The last one, I don't know which one was on the device because the motherboard was damaged. It is important that it works on bizhub c224e
            • copier tech
              • 8144
              Thanks, see attached procedure.
              Precedure to fit a used MFP board Revision 6.pdf
