C658 J-9903
  • apn821
    • Nov 2021
    • 5
    C658 J-9903
    Hey everyone. I've got a C658 that has a J-9903 jam code that won't go away. There is no copy or print job waiting to print. Ethernet cable has been removed. The machine will reset and try to come to ready but eventually it will show the J-9903. Done a complete unplug and reboot. The only thing i haven't done is a data initialization and firmware flash. Never had a J-9903. I've had J-9901. Any recommendations? Thanks.
  • Synthohol
    Certified Konica Expert
    • 5885
    id back the addy book and settings up to USB and initialize, reinstall movie data, pdf data and see if it goes away. the "controller jam" could be a loose side guide changing the paper size mid print.
    • pickle8486
      • Aug 2013
      • 26
      Had this same issue 2 weeks ago. Go into service mode and see if there are color registration errors. If so a drum has either recently been replaced that is defective or has gone bad, for us it was the K drum. we replaced alot of parts to fix this issue just to find out the drum was bad.
      • Andysnave
        • Jul 2018
        • 5
        I've had exactly this problem. Clean the PH assy with the cleaning wand. My problem was a leaky black dev unit depositing dev onto the rear of the PH assy so the machine couldn't stabilise correctly. Replaced dev assy and vac out and all was okay!
        • Albonline
          • Sep 2008
          • 1153
          stop the machine during color registration part of warmup ,see what's on the belt. Check the print head .
          • Tech09
            • Apr 2020
            • 147
            Have you done a System Error Clear? Whenever I have a jam of any kind that just won't clear, I open all the doors and pull out all the trays, cycle power, let it boot up and close one thing at a time. This should help narrow down what's causing the code. Would also flash firmware, even just re-flash the same version if it's already at the current level.
            • allan
              RTFM!!
              • 5462
              Have a call with the same issue. Wonder if this can happen if one of the drum of dev chips loose contact during stabilization? Seems like this happen after a K drum change...
              Whatever
              • tsbservice
                Field tech
                • 8043
                Hey allan nice to see you are back mate.
                pickle8486 said yes. I will go and check chips and parts maybe something is fouling machine.
