ERROR "Work ram overflow" when printing almost any file on bizhub c454e
+ More Options
Posts
  • Copycrazy
    • Sep 2018
    • 32
    Hello
    I have a printer, Konika minolta bizhub C454e with 230.000 copies.
    I am getting this error "Work RAM overflow" when printing almost any file. Pdf's about 5 mb or more trigger this error.
    I have an old bizhub c220 and I never had this error. It prints 100 mb files without problems.
    I have tried to format the HDD in service mode. It don't work. The ram overflow error happen when printing on usb and Network
    Where is the fault?
    What should I pay attention to?
  • Albonline
    • Sep 2008
    • 1144
    run a diagnostics check . ram is ram not hdd. some ram is built onto the main board ,but i belive the work ram is addressed to the dimm memory.
    • Copycrazy
      • Sep 2018
      • 32
      Hello
      Thanks for the answer
      Exactly what type of diagnosis? Can you recommend which option to select in the service mode?
      • Albonline
        • Sep 2008
        • 1144
        Do you have a service manual?
        • Synthohol
          Certified Konica Expert
          • 5794
          did the hdd format ok?
          choose spool print jobs to HDD in admin mode.
          some pdfs have so many layers the copier cannot flatten them ive seen.
          have you tried sending it once in black only? just to see if its the amount of data it needs to rip overflows the ram?
          i have an extra UK-211 expanded memory i could send. which side of the great pond is your mailing address?
          • copier tech
            • 8131
            I'd start by updating the firmware & check / update the driver.
            โ€‹
            • Copycrazy
              • Sep 2018
              • 32
              No, i don't have. I am not a technician.
              Just a user worried about solving a problem that doesn't let me work in my humble company
              • tsbservice
                Field tech
                • 7966
                I would swap HDD if you can't format it.
                Those are already old and HDD isn't exactly the robust part of the machine. You will need movie/animation data after that but machine should work with that warning.
                โ€‹โ€‹โ€‹
                • Gift
                  • Mar 2011
                  • 2458
                  I'd also check driver (don't use generic/class drivers, get the original PCL6 driver from KM website) and port (use tcp/ip port) settings first and only use acrobat reader for pdf printing.
                  • Copycrazy
                    • Sep 2018
                    • 32
                    I have solved the problem. Now it works ok.
                    On service mode --- System2 -- HDD -- Marked as Installed
                    Thank you for all
                    • mascan42
                      • Oct 2008
                      • 481
                      Thank you for all
                      How did you format the HDD if it didn't know one was installed?
                      • Gift
                        • Mar 2011
                        • 2458
                        He wrote that he "tried" guess that was a little miscommunication/understanding issue^^
                        Copycrazy thanks for updating the thread with your findings...
                        • Copycrazy
                          • Sep 2018
                          • 32
                          Printer let me format the hdd despite it was marked as not installed
