Konica 458 Toner bottle not turning in test mode.
  • 40yearsplus
    • May 2020
    • 113
    I just began troubleshooting this but did find that the toner bottle is not turning to add toner in the test mode. I had the toner deleted error i reset. In forums some said it was the Developer or Drum although this bottle should turn in the Test mode. The machine cycles and then once in a while the sub hopper motor turns which makes a clicking noise so I may have more than one problem. Just asking all what anyone has found to be the problem you have found when your toner bottle does not turn in Test Mode -Add Toner. I am going to search the manual also but wanted to know what anyone's known first problem is. Thank You
  • Woxner
    • Jul 2011
    • 851
    The bottle won't turn if it thinks sub hopper is full in toner add. May be bad sub hopper . What is the toner ratio under state confirm
    • 40yearsplus
      • May 2020
      • 113
      Yes the ratio in state confirmation is low. Like 1.7 had no idea the bottle would not turn if sub hopper was not working. There is a clicking coming from it. But you have seen the toner bottle not move in test mode? That's a great help if you have seen this. Let me know and Thank You.
      • Mr Bo
        • Mar 2023
        • 28
        I also have a machine that is having an error of not rotating the toner cartridge when Manual add toner. I have replaced the new toner cartridge and cleaned the Hopper, toner empty sensor,Replaced Toner cartridge moto K/ (M25) but the situation is unchanged. TCR ratio low.
        Maybe you need to replace the control board for Toner cartridge moto K/ (M25)
        • Albonline
          • Sep 2008
          • 1151
          check the subhopper full photosensors, they get loaded with toner .
          • Albonline
            • Sep 2008
            • 1151
            ive cleaned these b4 to no avail ended up havening to replace the ps's
            • wedotek
              • Mar 2021
              • 17
              Hello.
              Try this:
              1. Call the Service Mode to the screen.
              2. Call the Enhanced Security to the screen.(Stop -> 0 (Zero) -> C (Clear) )
              3. Touch [Engine FW DipSW].
              4. The switch corresponding to the colors to be reset is highlighted (ON state) in reverse video.
              34:K
              5. Touch [END].
              6. Turn OFF and ON the main power switch.
              • 40yearsplus
                • May 2020
                • 113
                My original problem ended up being that sub hopper, I replaced it and the toner spun. There is also a piece of plastic that can fall off the agitator in the hopper and keep the plastic toner height sensor from actuating I have seen in the past. Glad everyone got running also eventually. Thanks for the help
