How to change fuser belt Bh758?
  • Albertoner
    • Jun 2016
    • 6
    Hi, does anyone know where I can find a manual or tutorial on how to change the fuser belt on the Bh758? Thanks
  • copier tech
    • 8172
    Here's a link to the service manual which covers replacing the fuser unit.
    https://mega.nz/file/5d1yUDRY#OTP9i5...mMAX_bXJ1JjEP0
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      I think this C654 video is the same fuser or very similar: https://www.youtube.com/watch?v=X7gbOfEGZWw
      • Albertoner
        • Jun 2016
        • 6
        Yes, I have already seen that video, it is very similar, but no, that fuser does not have pressure like the one on the 958, on the 958 that is different
        Thanks.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          I doubt you will find anything specifically for the 958 fuser rebuild. Just take apart while video taping or take pics. Lay all parts with screws in order they are removed and reverse when re-assembling. Best of luck
            • 23009
            Konica Minolta does not intend these fusers to be disassembled. I do not doubt your skills, but there will be no sanctioned manufacturers procedure. You'll have to figure it out for yourself. =^..^=
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              I look at rebuilding any fuser, etc this way, if they sell aftermarket parts for it then it can be rebuilt. Also if a human built it I can rebuild it.
