"8" series toner in "i" series?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4764
    Will the 8 series toner work in the i series? Of course with swapping the end cap & new chip.
    Thanks in advance
  • kingarthur
    • 1385
    I don't see why not - Katun sell DV units that will swap between those series
    AAV708D Yellow Developer Unit
    Katun Performance. Click Here! Katun Performance
    Katun Part No. : 47997
    OEM Part No. : AAV708D
    For Use In : Konica Minolta BIZHUB C 250 I, BIZHUB C 300 I, BIZHUB C 360 I
    Universal Product
    Maintain inventory more efficiently and cost-effectively with Universal Katun Products.
    This Katun part number is universal to the multiple OEM part numbers below.
    • Woxner
      • Jul 2011
      • 853
      I use 8 series toner in a lot of I Series. It works better. Doesn't streak drums or ruin fusers. Doesn't offset like I series.
