c658 pulling A3 back into exit section on double sided
  • ralleyman
    • Dec 2019
    • 5
    hi i have a C658 that whn doing double sided A3 it is picking up a sheet that has just come out when turning the paper over then causes the j3205 code, there is no finisher on this machine has anyone come accross this issue before.
    I have tried changingfuser temp and also it is a lot better if you set the paper to thick 1 but there is an occasional paper sticks in the exit but does not give a jam
  • kingarthur
    • 1385
    Re: c658 pulling A3 back into exit section on double sided
    If it has no finisher...has it got an OT fitted.....
    • ralleyman
      • Dec 2019
      • 5
      Yes it has the output tray it looks like there should be anbother tray between the top and botom exit on the exit assembly
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Sounds like you're missing the output guide that came with OT.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Synthohol
          Certified Konica Expert
          • 5892
          When using an output tray there are 3 half moon rollers that attach to the exit shift
          Sounds like they were never installed (not needed if there is a finisher)
          Error
          Jam 32-05, paper is curling up in the output tray after a few pages.
          Root Cause
          Some of the rollers included in OT-508 were not installed.
          Workaround/Fix
          Ensure all procedures are preformed during the OT-508 installation (see attached).
          • B0265
            • Jan 2007
            • 718
            The OT-508 is for the C759/C659, the OT-506 only includes the parts in srvtec's picture.
            • Synthohol
              • 5892
              from the knowledgebase...
              Jam 32-05 when exiting paper to the output tray OT-508
              Known Error
              Related Products:bizhub C659,bizhub 658,bizhub 808,bizhub 958,bizhub C658,bizhub C759
              Related Options:
              • B0265
                • Jan 2007
                • 718
                I think that must be a mistake, the eject rollers are different in the C658 compared to the the C659 so the extra rollers would not fit even if they were included in the OT-506.
