c1060
  • romario
    • Jun 2020
    • 192
    c1060
    Hello group, does anyone know the DIPSW to order the fiery to turn off when turning off the machine? fiery ic 415
    thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    dont do that, fierys should be shut down properly through its interface or CWS not just unplugged/shut off.
    • romario
      • Jun 2020
      • 192
      Correct, the fiery does not turn off, it only turns off if I turn it off manually, I want it to turn off automatically through its interface or CWS
      thanks
      • tulintron
        • Jul 2014
        • 668
        It is not DIPSW. It is within the Fiery settings. power synchronization
        https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
        • romario
          • Jun 2020
          • 192
          thanks I will check
          thanks
          • Ziggy
            • Feb 2018
            • 731
            You dont want to turn on power synchronization. If the customer turns the machine off and they dont wait for the fiery to shut completely down before turning machine back on it can corrupt the fiery and you will have to reload fiery firmware and possibly replace the fiery hard drive.
            • romario
              • Jun 2020
              • 192
              I want to activate synchronization but I can't find where. I've already searched in configure almost everywhere and I can't see, could you tell me where it is?
              thanks
              • Ziggy
                • Feb 2018
                • 731
                All Fierys don't have that option. If you have one with the power sync option you web into the fiery then click on the Configure tab after that click on the launch configure button . The power synchronization choice is on this page.
