c3350i toner line in middle of transfer belt
  • Danny
    Field Tech
    • Aug 2024
    • 9
    Carlos Louw
    Good day everyone
    i have a c3350i that when i do gradation the page comes out with a line of toner in the middle of the gradation pattern and demo pages has a color shift,please see attached
    i have taken out the transfer belt and cleaned the cleaning blade and i have swapped the transfer belt with a spare one and taken out the ph unit and cleaned it and i have replaced the idc sensor and i have done the color registration adjustment which has taken away the color shift
    SKM_C250i24092708180.pdf
    has anyone encounter this problem?
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Originally posted by clouw
    carlos louw
    good day everyone
    skm_c250i24092708180.pdf
    i've encountered it several times on a3 machines, and it was always the belt cleaning blade.
    Field technician since 1994
    • Danny
      Field Tech
      • Aug 2024
      • 9
      ive cleaned the cleaning blade and swapped it with another one and still getting the same result and thing else i could maybe try?
      • tsbservice
        Field tech
        • 8010
        Those are well known for bad IUs what are your TCRs?
        • Danny
          Field Tech
          • Aug 2024
          • 9
          k-6.41%
          c-8.72%
          m-7.28%
          y-6.83%
          • tsbservice
            Field tech
            • 8010
            Update firmware.
            Shake the cyan drum unit for 10 times, and print 30-50 internal full color test pages followed by the high agitation speed function.
            • copier tech
              • 8144
              Originally posted by CLouw
              Carlos Louw
              Good day everyone
              From your picture the blade is not cleaning the belt, most likely worn as is the 2nd unit you fitted.
              Fit a NEW transfer unit not a used one.
              • Max
                • Oct 2011
                • 557
                The line in the middle is the colour /reg calibration patten. That's how it supposed to look like. If that was the blade issue, the line would be smeared, this one is perfectly defined.
                Print out solid test pages, see which IU is playing up. Cyan tcr is tad too high but not critical. Laser glass cleaned?
                • 4Toon
                  • Mar 2023
                  • 112
                  If you manually turn the transfer belt does it clean that stabilize line off or does it stay on the belt? The IU units on this unit is just as bad as the transfer belt and waste toner bottles they all break or fault out. They have a 60 day warranty on all theses parts for a reason and not a counter.
                  Permanently banned from Konica SSD.
                  • Danny
                    Field Tech
                    • Aug 2024
                    • 9
                    hi yes, I've cleaned the laser glass
                    that line only cleans off my transfer belt after a few prints
                    any setting i can do to make the line go away?
                    • Danny
                      Field Tech
                      • Aug 2024
                      • 9
                      it stays on the belt when i manually turn it but it starts cleaning it away when i take off the cleaning blade and clean it again
                      • 4Toon
                        • Mar 2023
                        • 112
                        Something is wrong with the belt itself then. I would replace the whole belt
                        • femaster
                          • May 2011
                          • 1504
                          If you are in the US (not sure if it applies to other countries), KM has put the image units of a number of the desktop sized machines into the YPP warranty mix so they can be claimed under a page count. None of the other items however, just the image units. I have no idea what the expected life is on them, or how the percentage of credit breaks vs page count breaks down for them, but so far any that I have claimed have always been a 100% credit.
                          These are the desktop models I can see under the YPP list for us:
                          4700i
                          4750i
                          C3300i
                          C3320i
                          C3321i
                          C3350i
                          C3351i
                          C4000i
                          C4001i
                          C4050i
                          C4051i
