Bizhub c300i OCR scanner
  • Ghostlover34
    • Oct 2024
    • 15
    Hello friends, I want to do OCR scanning on my machine, but this feature is not available. Which program or software should I install and what is the price?
  • Synthohol
    Certified Konica Expert
    • 5805
    i believe LK-108 OCR font needs to be purchased (and additional ram if reqd) and enabled? for the copier to do it.
    IIRC it makes 2 files when it scans, the scan and the index file to look up location of the search string
    if you use omnipage and scan at least 300dpi it may work too.
    • AlaskaCopyTech
      • Jan 2024
      • 77
      Synthohol, you're right on the money. Need a license code from Konica and OCR data installed in service mode and it should work from there as long as it is turned on during scan.
      • Ghostlover34
        • Oct 2024
        • 15
        I need help purchasing and installing this
        • kingarthur
          • 1331
          You'll need to either buy it from KM, or a dealer
