Bizhub c650i faded k
  • pappyvonsillypants
    • Feb 2013
    • 30
    Hello.... I have a c650i and the k is super faded. sample attached at 180 in halftone pattern* test mode.
    The machine has not thrown 1 code, or 1 warning.
    steps at this point:
    replaced k drum, k dv, k toner, transfer belt, laser unit, the hopper, hv unit as well as dc power supply because why the hell not.
    I have marked the gears on dv unit they are driving. the drum is as well. The colors ymc are coming out properly?
    The meter sheet prints out, but sort of faded. I have been working on km for 23 years.... this is really angering as what else can it be? I by know means am a shot gunner of parts (except the dc power supply) I have replaced each item separately so as the answer is apparent. the firmware is up to date.
    I have stopped the all k test page as it enters fuser. pulled the belt and there barley is an image. I pull the k drum and it as well has almost no image. I have not tried the base board?
    I have attached some level histories as well. It appears k voltages are wayyy high but according to the manual its at the upper of the threshold as far as the table is concerned.
    atdc of k is at 6 and never really drops? any help will be greatly appreciated!
    This gallery has 5 photos.
  • Synthohol
    Certified Konica Expert
    • 5824
    have you done a background data reset and stabilize followed by scanning all 9-12 gradation sheets?
    • tsbservice
      Field tech
      • 8013
      Have you tried another pair of IDCS? They can read wrong patches on belt and tell machine to increase K voltages. I would love to know what is it cause had one similar and never forget how bad it was 🤣
        • Feb 2013
        • 30
        I have done a clear all data!
        No I have not tried the idcs! cleaned them yes, repl no. I will update with my findings.
        • tsbservice
          Field tech
          • 8013
          Another idea you can try EXCB.
          This gallery has 1 photos.
          • Ziggy
            • Feb 2018
            • 732
            Try checking this , I've seen this turned on causing light config and meter pages
            [Utility]
            • [Utility]
              • [Printer Settings]
                • [Basic Setting
            [Toner Save] Select whether to save toner consumption by reducing the printing density (default: [OFF]).
            • tsbservice
              Field tech
              • 8013
              [Utility]
              • [Utility]
                  • [Basic Setting
              Yeah I have seen this a couple of times but not on internal halftone pages.
              I believe the problem is something else causing abnormal high K voltages.
              • satisfactionbg
                • Jan 2018
                • 12
                I have a similar situation, but almost no image transfer and the problem is M, not K. I Swapped what you have + Expansion control board with the same result.
                It all points to a Mainboard issue.
                  • Feb 2013
                  • 30
                  thanks for the updates! I am in process of getting a new idc sensor assy.... super behind at moment, as time waits for no one.
